low oil pressure
    sorry guys no updates yet. car has a annoying gremlin that keeps draining my battery. have to fix that first since i miss driving a car with power in it instead of the slow buick.
      I had an F150 that drained the battery over night, turned out it was the alternator. Your results may vary but it's a place to start..
        Well imma check the window motor first. It started happening after I put in a new one. I kept hearing buzzing coming from the driver door after turning off the car
        Sent from my Z956 using Tapatalk
          should be no power to the window motors once the key is off. Power lock motor will have power available all the time though.
            Power lock motor? My power locks never have worked since I bought the car. Where exactly is it at?
              Inside the door below the latch. You may want to check the lock switch up on the arm rest; sounds like it may be stuck on.
                Gotcha will do. Thanks
                  So I took a look at the armrest and the switch next to the manual door locking mechanism was stuck downwards. Hopefully that's it for the problem. I'll take the battery to get recharged tomorrow since I don't feel like driving in this San Antonio traffic.
                    Yupp it was that switch. Now she works fine
                      Ah, simple things first.
                        Yes sir. Now to save up for the performance upgrades lol
