Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
Thread: low oil pressure
  1. #41
    Fan works as it should. Stop and go traffic, stays between O and the R on the gauge. Long periods of driving without stopping is when it starts giving problems. I'm planning on getting a separate tranny cooler with fan and see if that helps. And I'm in the process of doing a 3g alternator swap with electric fans and maybe a electric water pump.
    Sent from my Z956 using Tapatalk
  2. #42
    33,976
    also possible the water pump leak is sucking air at speed, and you're not actually moving water properly.
    91 Lincoln Mark VII LSC SE, triple black (Timewarp) - poly front bushings, KYB struts and shocks, Holley SystemMax1 lower intake, SilverFox AOD valve body, 246k and counting
  3. #43
    I'll change out the gasket and I'll update you guys on it. I'll do it maybe tomorrow after work.
  4. #44
    Full of Greenhouse Gas Tiggie's Avatar
    Mar 2006
    Moneta, VA
    4,027
    Any gaps around your radiator and the core support?
    1988 Crown Vic Wagon - daily
    1990 Country Squire - yard ornament (save me please)
  5. #45
    GMN Regular knucklehead0202's Avatar
    Apr 2015
    Southern Commiefornia
    1,405
    There's this dude on YouTube who threw it in the crankcase of his old 2.9 Ranger and it free'd up a sticky lifter(s) in seconds.
    Typically all the Old fords I've ever driven go to the middle and stay there as if there's some sort of buffer to keep them there. In your case I wouldn't worry about it as I'd expect it to heat up at idle..
    My first '90 literally NEVER got above "O" on NORMAL except the time it shit a heater hose. When I had the top-end done on the motor they found out the whole bottom half of my radiator was full of shit and getting ready to burst. They put in a new radiator and fan clutch at that time. After a complete top-end including new aluminum heads, 1.7 rockers, intake, TB, injectors, MAF, etc. it ran cool as ever despite me beating on it and manually shifting to keep it in the radically-different powerband.
    New car had a new water pump and radiator flush shortly after I got it and it crapped the pump. Always ran around "R" before and still does. A few weeks ago on a particularly warm day, I was awaiting a pick-up/drop-off in a parking lot in the car with the A/C running for the puppies. Watched the gauge climb slowly from "R", then "M", then it hit about the middle of "A" and wavered. Went down a little, up a little, and I freaked out and shut it down. Rolled the windows down and sweated for a bit. Once we got underway again it swiftly went back down to "R" but really shook my faith. It has a new water pump and fan clutch, the coolant looks great, but i'm scared. May just stick the new radiator I tore out of the other car in there for safety's sake. Driving the boat out to the desert this weekend so we'll see how much I get done tomorrow.
  6. #46
    sorry guys no updates yet. car has a annoying gremlin that keeps draining my battery. have to fix that first since i miss driving a car with power in it instead of the slow buick.
  7. #47
    Sep 2014
    Warren, MI
    3,702
    I had an F150 that drained the battery over night, turned out it was the alternator. Your results may vary but it's a place to start..
  8. #48
    Well imma check the window motor first. It started happening after I put in a new one. I kept hearing buzzing coming from the driver door after turning off the car
  9. #49
    33,976
    should be no power to the window motors once the key is off. Power lock motor will have power available all the time though.
  10. #50
    Power lock motor? My power locks never have worked since I bought the car. Where exactly is it at?
  11. #51
    Mar 2006
    Moneta, VA
    4,027
    Quote Originally Posted by dan View Post
    Inside the door below the latch. You may want to check the lock switch up on the arm rest; sounds like it may be stuck on.
  12. #52
    Gotcha will do. Thanks
  13. #53
    So I took a look at the armrest and the switch next to the manual door locking mechanism was stuck downwards. Hopefully that's it for the problem. I'll take the battery to get recharged tomorrow since I don't feel like driving in this San Antonio traffic.
  14. #54
    Yupp it was that switch. Now she works fine
  15. #55
    Sep 2014
    Warren, MI
    3,702
    Ah, simple things first.
  16. #56
    Yes sir. Now to save up for the performance upgrades lol
