So I just started with the mass air swap. Ran into some challenges that I hope to get your opinion on.
I noticed that I have 60 terminals and far fewer holes on the back of the connector. I looked for threads on mass air from my phone and settled on 87GTVic's RR thread where he said that drilling is needed. After an hour of getting the courage needed for this task, I drilled a 1/8" hole in the back of the green cap. Just barely fits the pin, but it hit a wall or something that prevented it from coming through terminal. I think I saw a hole, but it just wouldn't go through. So, I took a tiny drill bit and went through the terminal end out the back of the connector. Then drilled it out to 1/8" from the back. The pin goes through, but I can't get it to lock in. It was getting dark, so I called it quits and wasn't able to get back to it. This is for the VSS+ I hope I just need to play around with the pin until it locks in. For those of you that have done this; how did you accomplish this part of the swap?
