Page 26 of 26 FirstFirst ... 16242526
Results 501 to 520 of 520
Thread: kishy's 1985 Country Squire
  1. #501
    Member Stocker's Avatar
    Jul 2014
    The Land of Sky-Blue Waters
    86
    This came out of Ward's Automotive Yearbook. According to those books, '83 Ford production was added at the Mercury plant in St. Louis, and then when Oakville switched over to the Tempo the following year, its Panther production was moved to St. Thomas (presumably because the end of the Fairmont opened up a production line). It did say that February '85 is when St. Thomas became the sole source for fullsize Fords and Mercurys when St. Louis started retooling.
    1985 LTD Crown Victoria
    1992 F-150 XLT 4x4, 351W
  2. #502
    Sep 2014
    Warren, MI
    5,710
    I wonder now when my '85 LTD was built. It was not built in St. Thomas.
  3. #503
    Just to add fuel to the fire my old 85 was built in September of 84 and was built in St. Louis.
  4. #504
    all the CFI are belong to me
    Feb 2014
    Windsor, ON
    1,654
    I was moving cars yesterday and in doing so, found that the driveway stain I've historically attributed to the Lincoln's previous power steering pump had become much, much larger. Like, the size of a Panther hood. The car sitting in that spot now was the wagon, and the new fluid was red.
    So, put the wagon up, got under, found that the O-ring for the retrofit trans drain plug had squeezed out of position and that's where the mass quantity of fluid was coming from. Easy.
    Drained it into a bottle, dug around the garage for a copper washer (think brake system, but smaller), and solved that problem. Same fluid that came out went right back in, since it's new anyway.
    I will note that the fluid has darkened a fair bit, but that could easily just be new fluid washing old out of all the nooks and crannies. Regardless, it shifts absolutely fantastic, so...whatever happens, happens.
    Also, the rear main leaks...a lot.
    83 GM 2dr POTM 10/2019 | 84 TC POTM 1/2017 & 4/2019 | 85 CS | 85 Ranger | 91 GM POTM 12/2017 | Junkyards
  5. #505
    Mar 2010
    Lewisville, TX
    21,332
    self undercoating.
  6. #506
    Member BigMerc96's Avatar
    Jun 2011
    I can see Detroit from here
    517
    self undercoating.
    self preservation.
  7. #507
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,276
    Self oiling.
    '10 Escape LTD. V6 AWD, K&N, Bullitt wheels.
    '91 Mercury Grand Marquis Colony Park Station Wagon. K-Code, 4.10's, Repacked Trac Loc, MK VII LSC Engine, 'Stang Upper Intake, 'Stang Air Tube, K&N, 65 mm T-Body, 'Stang Headers, 'Stang Cat Pipe,'Stang Torque Convertor, 2 Chamber Thunderbolts.
  8. #508
    Nov 2014
    Evans, GA
    1,522
    Self changing.
  9. #509
    Nov 2012
    Shelby Township, MI
    2,974
    I had what I thought was a rear main leak once. Turned out the flex plate bolts need thread sealer and I hadn't put any on. I redid the seal anyway, but when I pulled the first flex plate bolt it was like I pulled a drain plug for a second.
    If you need to get at the rear main and want to go the route of removing the trans, I've got a cheap trans jack if you have no other option. I also have the special tool to install the seal and repair sleeve if you choose to install a sleeve. The special tool was cheap enough for me, basically a PVC cap with a special ridge for the sleeve.
    ~ 1997 GMC Yukon - wannabe winter DD - returning summer 2020, I finally have an engine
    Gone but not forgotten:
  10. #510
    38,379
    Last one of those drain plugs I installed, I brazed in. I didn't care for the plastic sealing washers so its now permanently a part of the pan, sealed forever with brass rod. The inner drain plug has a copper washer. My local hardware store has a good assortment of copper seal washers in metric and standard.
  11. #511
    Feb 2014
    Windsor, ON
    1,654
    Oil change day. 74,263km. 446km on this oil, which is a mix of leftover mixed conventional 10W30 and 5W30 plus about a litre of Dex/Merc (re: the potentially false tale that ATF cleans up engines). It came out black as night, so there's that. This is the second oil change in owning this car; the first change was also a very short interval and happened after the timing set and intake gaskets right before it hit the road.
    New oil is a Shell-manufactured synthetic blend diesel/HD 10W30 in a store brand pail. It's probably Rotella T5 but there's no way to really know that. New filter is a FL1A. This combo will run for a standard 4800km OCI. I put copper washers on the drain plugs as the plastic ones were leaking, as they always do.
    The Citgo C1A filters ($1 filters I bought because I knew I'd be doing a couple short OCIs) seem to have a very functional anti-drainback valve. Maybe more functional that our beloved FL1A. The car had been left on ramps after the trans drain plug stuff above, and not run since, and yet when I pulled the filter it was completely full of oil and there was a significant suction/draining sound when I threaded the filter off (air entering). If I had a good way to evaluate how well they actually filter I'd be tempted to buy a bunch more if they're still on RockAuto.
    Didn't do chassis lube since that was all done 446km ago.
  12. #512
    38,379
    wonder who makes the cheapie. There are only so many companies manufacturing stuff. Champ Labs makes a ton them with all manner of brand names.
  13. #513
    Jul 2014
    86
    Glad to see I'm not the only one who writes down the date/mileage/etc. on the top of the oil filter box...
  14. #514
    Mar 2006
    Bedford, VA
    5,360
    Quote Originally Posted by Stocker View Post
    Same
    1988 Crown Vic Wagon - daily
  15. #515
    38,379
    I bought a big roll of oil change stickers for short money. I'll be able to sticker my own cars until I die without buying more.
  16. #516
    Sep 2014
    Warren, MI
    5,710
    ATF does work at desludging. Why transmissions are always so clean and if further testing needs to be done, schmear it all over something greasy at a yard and see what happens.
  17. #517
    Nov 2005
    2,276
    Also can work as penetrating oil in a pinch.
  18. #518
    Feb 2014
    Windsor, ON
    1,654
    As with the 83, this was at the 2019 Metro Detroit meet today. Following the meet, some photos were taken.
    Following are also in the 83 thread, with a couple of just this car alone which I didn't include there.
    This car did shred its belt today after parting from the meet. We peeled off the shredded part and it made it home using the rubber band scrap that was left. Of course, I hadn't put spare belts in either car. The failed belt was on it when I got it and did look like it was kind of old.
    Also, the charging system light is now on pretty much solid, at all times the key is on. Still a stock 1G externally regulated system. It's almost certainly a short to ground in the light bulb circuit because there is no actual reason I can find for the light to be on, however, the fact the alternator works at all does seem to suggest it can't be shorted as the alternator won't excite without that circuit...it's a mystery.
  19. #519
    Sep 2008
    Whitestone, NY
    18,820
    Nice photos. Cool areas.
  20. #520
    38,379
    does the light go out if you unplug the regulator? If it doesn't, its a short to ground. If not its something in the reg causing it to turn on. If the resistor across the back of the bulb is missing that might also cause it to come on.
