Page 18 of 26 FirstFirst ... 81617181920 ... LastLast
Results 341 to 360 of 517
Thread: kishy's 1985 Country Squire
  1. #341
    Sep 2014
    Warren, MI
    5,546
    I thought you were going to end it with I forgot to put the fitting on.
    LMAO!!
    Dammit I've done this so many times or when I go the lazy route and buy pre flared line I sometimes forget to make sure the fittings are at the ends before I start bending... Luckily it's been about 15 years since I've made those mistakes.
  2. #342
    37,883
    hm, lets see, last time I had to bend a brake line for myself was about 2 years ago, so its been 2 years since I made that mistake.
  3. #343
    all the CFI are belong to me
    Feb 2014
    Windsor, ON
    1,595
    I misspoke. The green brake line is not PVC-coated, it's something else that I don't entirely understand. Regardless...yeah.
    I double flared the line (and yes, I forgot to put the flare nut on this time...) and used an SAE union, joining it to another piece of line up to the master cylinder. The booster and master are just mocked up in position right now so I could get the lines right.
    I used junkyard-harvested metric flare nuts for the master and connections to the flex lines. I bent up a nice looking driver side line and now the front lines are done, assuming no leaks appear when it's time to put fluid in it. The front to rear line still needs to be done, as do the lines on the axle. I'll probably focus on engine stuff before I move to the back of the car. Timing set, water pump, valve cover gaskets, intake gaskets, radiator. The new hood can go on after that. It will probably keep the 4-eye header panel until it's on the road and then swap to the 2-eye header panel at a later time. Just prioritizing things.
    Exact applications are escaping me but this master is the same as what came on my '91 new. All valving is contained to the master, nothing on the frame rail. Both fronts connect to the master with bubble flare metric flare nuts (yes, on my 91 it was that way as-new). The rear drums go through one of those inline valve things threaded into the rear port of the master.
    83 GM 2dr | 84 TC POTM 1/2017 & 4/2019 | 85 CS | 85 Ranger | 91 GM POTM 12/2017 | Junkyards
  4. #344
    37,883
    The frame-mounted combo valve went away by about 1990. Seems hit or miss in 89.
  5. #345
    Feb 2014
    Windsor, ON
    1,595
    I seem to recall that I have seen 88s have the combo valve, and 89s have a different valve/splitter that does less and is half the size (the master on those looks like this one, however has only one front outlet instead of two). Then 90-91 fully adopted a more modern-looking deal.
    Ultimately I suppose it doesn't matter: most people will repair what they have to functional equivalency of what it was when they started. I just resent those frame-mounted valves in a variety of ways and couldn't wait to get it the hell out of there.
    I'm not sure how dual-system separation works with the newer master. I kind of suspect that functionality is basically lost (one or two pumps still work after loss of fluid, beyond that, into the wall you go). As my Ranger proved, it didn't exactly help that much, since the shuttle valve didn't seem to properly seal it off and I lost my fluid anyway. When all is in perfect working order and brand new, I'm sure results are more favourable.
  6. #346
    Sep 2014
    Warren, MI
    5,546
    The green coating or whatever is some sort of polymer, least that's what the label said on the brake line I recently bought for Ashley's truck. I too like to use the word "harvested" when liberating parts from scrap yards. "Recycled" is another good one when around hipsters and greenies.
  7. #347
    Feb 2014
    Windsor, ON
    1,595
    I figured out the exhaust leak, but not why it changes over time: the smog tubes are present on the heads, however they are corroded off after a couple inches on each side and just breath freely. I will probably do that trick where you take them off, grind the tubes off the nub things, then put the nubs back on reversed so they block the holes. That should solve that problem without needing to deal with the BS that goes along with using the plugs (likely need to run a tap into the holes re: chunks of carbon). I had forgotten that the TAD/TAB doohickey is entirely absent on this car, though the control solenoids thankfully remain (if they are removed, it will set a code)
    Got eyes on the AC evaporator through the blower motor hole. Not completely clogged up with dirt, so that's good. Blasted what I could out with air and that'll have to do.
    Blower motor likely needs to be swapped, it makes noises. Bought two closeouts from RockAuto, that should solve that.
    Removed the AC lines and drier. Will re-add AC later, for now I'll benefit from the working room in the engine bay.
    Orifice tube did not want to come out at all. Eventually I used a screw driver to hammer the metal tube through the rest of it, then drove a wood screw into the body of the orifice tube, and when that couldn't make it budge, I took a propane torch to it. Can't be tight if it's a liquid, right?
    Tie rods are installed. New idler arm is installed. Pitman arm seems tight so that's good. Steering box leaks, but they all do, so that's whatever I guess. Greased the front end; ran out of grease just as I finished up with the final grease fitting. Will need to buy more of that.
    The $20Cdn RockAuto closeout Kelsey-Hayes fully loaded brake calipers will be quite nice...they have an anti-corrosion coating on them. Too bad I'm going to hide them behind steelies.
    Garage roof might have a leak. Either that or a resident animal in the attic peed at a strategic time while it was raining. I'm more inclined to suspect it's just rain, but it was very weird that the dribble from above suddenly began and then suddenly ended. Can't really do anything about it either way until this car is out so whatever.
    I'm going to need some sort of spiked car cover for the '91. Little raccoon hand-prints all over it. They're my favourite animals, but I want them off of my cars.
  8. #348
    Sep 2008
    Whitestone, NY
    18,643
    I caught a cat in action a couple times on top of mine...Its covered BUT STILL STAY OFF.
    I should really do inners and outers on my front end. I just dread setting up the toe/making the steering wheel centered.
  9. #349
    Sep 2014
    Warren, MI
    5,546
    Racoons look cool, that's about it. Unfortunately for us humans, they're also very clever.
    Those calipers do look nice, especially with their fancy zinc coating. Last time I looked into calipers that had said coating, I think they were $60/piece or more.
  10. #350
    Feb 2014
    Windsor, ON
    1,595
    I now suspect the animal which has gained access is an opossum. And a water damaged (evidently from a past roof, as I don't think there are current leaks) section of the drywall ceiling in the back room (storage/"stockroom") has become no longer attached to the ceiling, forming an approximately opossum-sized hole. Interesting.
    Blocked off the air injection ports on the heads. I did the thing where you just flip the pipe connector end pieces so they block the holes. This will probably allow a small exhaust leak in some conditions but that's better than the full sized exhaust leak it had previously.
    Began fuel lines. Instantly regretted using Poly Armor steel lines; should have just used nylon like I planned. Return line is more or less done though. Compression fittings may need tweaking. Or maybe outright rethinking. I'll probably steer towards using nylon on the supply side because it totally defeats the benefits of the poly coating if you scrape it all off trying to get the line in place.
    Resumed working on brake lines. The main front-rear line is now done, and rear flex hose is installed. Just need to rebuild the drums and put new lines on the axle and the brakes will be more or less done.
  11. #351
    Feb 2014
    Windsor, ON
    1,595
    Found a rather large exoskeleton that a spider molted out of. Kind of wigged me out, a bit, knowing that at one time the rest of the spider was there with it.
    Continued my battle with 5/16" Poly Armor steel fuel line. This is a very regrettable choice of material. My flare tool agrees and wanted nothing to do with it, so I coerced it a little. I need to find a really good quality flare tool and make all my flaring hate go away. Maybe something pneumatic if available.
    Need to buy some 1/4" fuel-rated rubber or nylon line for the evap hose. Factory did steel, but I am quickly losing my patience with metal lines.
    Supply line is "done" working backwards, to the torque box, roughly. It is a mangled mess aft of that, but will get me back to the fuel filter where it needs to go. I'll be doing another one of those flare-union-flare-quick connect deals and that will get me into the factory rubber-coated-nylon flex line to the filter. I am probably going nylon for the duration aft of the filter. It's on hand, I just have concerns about it chafing on stuff. I might put some loom on it.
    The compression unions turned out to be junk. In order to sufficiently tighten one to make the steel line lock into position without freely spinning, I had to tighten it to the point the threads just ripped off. Parts store won't consider a refund without the manager approving during specific hours of availability in the week. I get their angle; if I had cross threaded them and screwed it up myself, I would deserve nothing. Unfortunately the product is just inferior in this case. It is probably going to result in me re-doing the return line rear end. It seems like the front end "took" OK, but my confidence level is not great. For a fuel fitting directly adjacent to a heat source, I think my confidence level should be higher.
  12. #352
    Sep 2014
    Warren, MI
    5,546
    That kind of looks like a brown recluse. Google images of bites from that thing and not only will you be spooked, but you won't have an appetite for at least the remainder of the day.
  13. #353
    Mar 2006
    Bedford, VA
    5,144
    Didn’t know you could get those quick connector ends new. Good to know, thanks kishy.
    1988 Crown Vic Wagon - daily
  14. #354
    Nov 2012
    Shelby Township, MI
    2,848
    I tried the same thing, using a clamp, with that type of flaring tool (mine is the cheapie from HF). It seems to be that all flaring tools of this type have the 5/16" hole in the center, farthest from the pressure points at each end resulting in far less clamping force. Never had an issue with 3/16" which is closer to the end, also have never used one of these tools for any other size line.
    I ended up giving up on the stainless line I harvested from a '95ish Taurus.
    Quote Originally Posted by kishy View Post
    ~ 1997 GMC Yukon - wannabe winter DD - I'll fix it eventually
    Gone but not forgotten:
  15. #355
    Feb 2014
    Windsor, ON
    1,595
    Nah, not thinking recluse...leaning more towards wolf spider or a huntsman (sparassidae). Either way, I'm not enthused about one potentially being in my garage. I'm hoping it molted before the car was on my property lol.
    It's sold as an adapter from nylon to steel - note that one end is barbed for nylon and the other is the quick connect male. In this case I cut off the nylon barb and flared it.
    RockAuto carries S.U.R.&R.'s version of it, part K150. I think they have the shipping weight set wrong because it's kind of spendy to ship, but if you can't source them locally, that will get you a pair.
    It's a fair bit cheaper than buying the Dorman (or others) 1ft length of tube, double-ended with those ends, and then cutting it in half...those tubes are typically closer to 20 bucks (US) each.
    Quote Originally Posted by VicCrownVic View Post
    The C-clamps got it done. They proved to be necessary for both the Poly Armor and the plain steel, so the coating didn't affect it +/-...the problem is of course that many of the flaring tools on the market are identical, made by the same Chinese or Taiwanese tool makers, and all of the identical ones will have the same shortcomings. It's strange to me that this problem wasn't corrected early on because 5/16" is not really a rare line size. Surely the makers know about these issues.
  16. #356
    37,883
    Only thing I've ever used compression fittings on is copper or plastic line. The brass ferrules just don't bite into steel. You need stuff specifically designed for steel tubing, usually instead of the football ferrule you get a two piece thing that has an obvious one way only assembly method. Standard compression lets you put the brass bit in either direction and it doesn't matter. Swagelok, Yor-Lok, or Let-Lok (different brands of the same thing) are usually the thing to use there.
    or just double flare them, but fuck flaring steel 5/16" line.
  17. #357
    Feb 2014
    Windsor, ON
    1,595
    Yeah...I think I'm going to ditch the compression fittings. Really not confident in them for this application. I should be able to get enough line free to flare them, and if that were to fail, I'd rip the new line out and just go nylon. Should have done that originally. Live and learn.
    Supply line is now done working back from the throttle body to the fuel filter. Factory line off TB, factory nylon line to the frame rail, new line as pictured in the most recent pics above. Now that new steel line ends under the passenger front door, and transitions to nylon, which goes to where the filter lives. New quick connects were used because the old ones pulled apart and didn't look great.
    Yes, I forgot the flare nut there and had to redo it.
    I think I'm doing nylon from the filter back to the line off the tank. So done with steel.
  18. #358
    37,883
    My Mark VII rocks all-original nylon lines from 1991. Its the way of the future.
  19. #359
    GMN Regular slack's Avatar
    Mar 2013
    Long Island, NY
    1,223
    Any issues with the nylon getting brittle with heat over the years? (I guess probably no worse than steel getting rusty... )
  20. #360
    37,883
    It has one repair splice from before I owned it, but otherwise no issues that I know of. I've never gone under there and poked at it just to see if it will fail but it hasn't given up on it's own. Panthers use the same stuff at the fuel filter, at the top of the tank, and from the frame to the lines on the engine, along with a section at the front and rear of the fuel rail. None of that ever seems to fail either.
