kishy's 1985 Country Squire
    Photos!
    8/08 with friend's Bonneville
    8/12 engine bay general/overview
    Heater core still bypassed, AC brackets absent. Junkyard parts will be needed to make AC happen in this car. The way I got the car, there was no provision for a tensioner pulley.
    Yes, I loosely ziptie my plug wires to the control arm to keep them off the exhaust...one day I will get better at properly assigning the wires to their correct homes. It would be nice if the replacement sets would come in the same lengths as the factory ones, but they never do.
    8/13 put hands on the tailgate door card. It is broken, all the tabs for the retainers are broken, and it also smells oddly like BO. It must be replaced.
    8/19 headlight relays! This has hopefully made it so I'll never need to replace the headlight switch. Light output is significantly improved, didn't think to check voltage before/after. Amazon relay sockets definitely lied about having 14 gauge wire but I made the affected length as short as possible and it seems to be doing fine. Notably, the high beams no longer have two intensity levels (normal high beam vs holding flash to pass while high beams are already on), which speaks to the drop that was happening in the headlight switch area of the circuit.
    8/20 impromptu photoshoot
    Current driver: Ranger
      looks nice sitting next to it's ancestor.
      14awg insulation with 18awg wire inside? I've found that on cheap wire before. Not sure why but I guess people think if the wire looks fat, it must be able to carry a fair bit of current.
        1966 Ford Fairlane woody wagon. Don't see those very often. Looks like that might have a 6 cyl motor in it ? That was the standard motor, The motor badging is missing on the fender,which normally meant it at least the car started out as a 6 cyl. Maybe someone removed the badging ?
        I had a 67 Dark green 2 dr. Fairlane GTA . If I remember right, it had a 390 motor. Bought it for $400 in 1975. Nice car. Now they are worth some bucks when you can find them.
          The wagon (the 60s one) is for sale, I believe he wants somewhere in the area of 15k. It's been for sale for years.
          Exhaust is newerish, hanging poorly, and is dual. Not sure how common dual would be on a 6 cyl but it's certainly possible.
          I seem to recall concluding it must have been a Torino since it's a rather small car, but I don't know the lineage of stuff back then well enough to say, and Wikipedia is too many clicks away right now.
          14-ish-looking insulation on somewhere between 16 and 18 gauge wire, yes.
          Today, achieved a couple things.
          Replaced U-joints. The old ones were not making noise but one was too seized to move by hand, and both had grooves cut in the cross piece by the bearings which were no longer bearing-ing very well.
          I'm hoping this will cut down a vibration I've been hunting for a while but I'm suspecting that's one of the tires (not out of balance, just old poor condition tire).
          Reinstalled the cruise servo and cruise module (not the one from this car as I couldn't find it, but the one from the 83 Town Car). Cruise does not operate. Need to investigate this more in-depth. I have the EVTM.
          Fixed illuminated entry. The key-on voltage wire had somehow been pulled out of the junction block beside the fuse panel. This wire is what tells the module to kill the lights once the key is on. Previously, the lights stayed on for the full timer sequence even if the key was turned on.
          Changed the air filter. I am not 100% sure but I think it's a part I had never changed in the initial work I did on it since it looked clean enough.
          Replaced the super heavy TV return spring with one harvested in a junkyard some time ago. Pedal is a lot lighter. TV linkage does not get stuck anymore (thanks to lots of lubrication and now regular use) so I think this is the right way to go.
          Reinstalled the factory "cold air intake". More accurately I think it's a different junkyard harvested one, as I have several, and I think the one from this car was toast.
          Finally cleaned the rear quarter windows. I believe the grossness on them was mostly wasp spray from the initial recovery of the car, but not sure.
          After many months finally got my police steelies back from the guy who was coating them. Finish is good, not perfect, I don't care now. Alignment appointment is Monday during the day, tire appointment is Monday after work. Looking forward to seeing this one on some new shoes.
          76,693km on the odo.
          Overall underbelly:
            Who needs Flowmaster when you got the optional equipment high flow muffler?
              I love that Fairlane, I have wanted a 68 ish wagon for years.
                The patina on your "wood" panels is cool. I have wanted to spray some dull clear mixed with a little grey to make The MegaMerc's "weathered" panels look like driftwood. Don't know how the tape would react too paint tho...
                  I can hardly contain myself right now, I'm absolutely giddy about this:
                  2020-08-24 @ 76,983km
                  Front end aligned at a an old-school shop that knows their stuff.
                  Tires purchased from Canadian Tire and mounted on my police steelies which have been epoxy-coated, and have aluminum dog dish caps.
                  225/70R15 Goodyear Wrangler SR-A at a very economical $108 Canadian each.
                  The view as I walked out of the tire place...
                  Absolutely stunning. This is the exact image I had in mind for this car. It's the exact amount of rake I wanted, the exact ride height, the exact wheels and the exact tires.
                    Bonus points for the shop for putting the weights on the back side!
                    Looks good.
                      Aren't Wranglers truck tires? Fronts look a bit "meaty."
                      +2 for weights on the back side, kills me when shops don't do that. I dig the steelies with dog dish hub caps as well. It's really coming together. So is the van, it runs, drives AND stops! Fine tuning is what's going to kill it..
                          Fronts and rears are identical, wagons just have bigger rear wheel wells and that combined with the narrower rear track on pre-90, plus the modestly wider track in the front due to the front end swap means any tire looks a little smaller back there. With the old tires I was considering spacers for the rear but I no longer think that's needed, considering the depth of the tire relative to the bottom of the wheel arches.
                          These are P tires, as in passenger as in usually car/small SUV. The Wrangler tire line often is on trucks or SUVs though. I specifically wanted the cheapest, major brand, white letter tire that I could buy, and this absolutely satisfied those requirements. I'm also glad I went up to the 225/70 instead of stock-correct 215/70 as I think they would have looked a little skinny. Between getting the wheels blasted (I don't feel he did a good job at this) and coated (I feel he did a good job at this, but I had to bring them back for some fixes after the first time) and the tires, and the wheel purchase from the junkyard, I believe I'm around $1200 Canadian into the wheel and tire package.
                          I hadn't even thought to ask about the weights going on the back, but I'm glad the tech did it that way. Didn't even look to see if they're rim weights or sticky weights. Newly coated perfectly clean wheels would take sticky weights well, so maybe that's what he used.
                          The car rides and drives fantastic now that it's aligned properly and is on good rubber. The speed-related vibration I was chasing seems to have been cured which confirms a tire was at fault. Steering is pretty much perfectly on-centre, box does have a small amount of the usual slop, but the rag joint is like new.
                            The white letters look good man. Glad the vibration thing is no longer an issue.
                              Looks great, love the RWLs.
                                Looking good to me.
