Results 1 to 10 of 10
Thread: A/C cutout relay?
    Member ZombieTown94's Avatar
    Nov 2016
    Tampa, Florida
    137
    Default A/C cutout relay?
    Ok, so here is my problem. Something has been draining my battery lately. Within 2 days it dies, from a full charge. Battery is new, alternator is new. I have used a voltmeter across the negative battery cable and the negative battery post, while pulling fuses and the number varied only slightly between fuses. I then got to this box (pictured). There are 3 relays in there. I noticed the "A/C CUTOUT RELAY" relay was quite warm to the touch. Once I pulled it, the number on the voltmeter dropped significantly. What is this relay for? What's it do? This dead battery thing is driving me nuts, and I think this may be the culprit. Click image for larger version.
ID:	47919Click image for larger version.
    -1994 Lincoln Town Car...always under construction
    Jan 2007
    Westmont, New Jersey
    10,110
    Relay turns off a/c at high loads/ wide open throttle/ start up. This would only be powered and grounded when the key would be turned on.
    Vicky
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar, GT40 Intakes With Remanufactured GT40P Heads, Contour Cooling Fans, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, Working A/C, Big Front Brake Swap, more mods to come soon!
    Nov 2016
    Tampa, Florida
    137
    Any idea why it would be warm, almost hot?
    19,583
    If the ECC relay isn't turning off, that could be why. It provides the power for the rest of the relays in the car (coil side). The WOT relay is the only one that's normally closed though. This may also indicate that the ECM isn't shutting down all the way either... which may indicate other issues may be at work as well like a shorted ignition switch. Easy way to test is to swap the ECC and fuel pump relays and see if the fuel pump stays running with the key on, engine off. May just need to replace those relays.
    Nov 2016
    Tampa, Florida
    137
    Hmm, I have multiple extra relays around so I did replace the 3 in there. We'll see if that changes anything
    19,583
    If not... I'd place my bets on a short in the ignition switch or some wiring between the relays and the switch (which would be a bitch to trace).
    Nov 2016
    Tampa, Florida
    137
    No thank you! Haha
    Anyway, replaced the relays and the car hasn't been touched since then. Just tried and it fired right up, didn't even feel weak. Normally it would have been almost completely dead in that time frame. I'm really hoping the problem is fixed now. The car needs to be my DD again soon
    19,583
    pop out the relay pack again and feel the relays. If they're not all hot and bothered... you're probably good.
    35,318
    shitty contacts inside the relay or at the socket will also make it hot. Its passing the compressor current through those contacts any time the AC is on. Sometimes the springs get weak inside the relays and it doesn't make solid contact. This one relies entirely on spring pressure to make the connection, it doesn't pull in like the others do.
    Nov 2016
    Tampa, Florida
    137
    Well I haven't noticed the relays hot at all since replacing them. Maybe things are finally going in the right direction. The car has fired right up every time. I guess I need to let it sit for a few days and try again, that would be a true test.. Thanks to everyone that helped out
