Ok, so here is my problem. Something has been draining my battery lately. Within 2 days it dies, from a full charge. Battery is new, alternator is new. I have used a voltmeter across the negative battery cable and the negative battery post, while pulling fuses and the number varied only slightly between fuses. I then got to this box (pictured). There are 3 relays in there. I noticed the "A/C CUTOUT RELAY" relay was quite warm to the touch. Once I pulled it, the number on the voltmeter dropped significantly. What is this relay for? What's it do? This dead battery thing is driving me nuts, and I think this may be the culprit.
A/C cutout relay?
If the ECC relay isn't turning off, that could be why. It provides the power for the rest of the relays in the car (coil side). The WOT relay is the only one that's normally closed though. This may also indicate that the ECM isn't shutting down all the way either... which may indicate other issues may be at work as well like a shorted ignition switch. Easy way to test is to swap the ECC and fuel pump relays and see if the fuel pump stays running with the key on, engine off. May just need to replace those relays.
If not... I'd place my bets on a short in the ignition switch or some wiring between the relays and the switch (which would be a bitch to trace).
Originally posted by sly View PostIf not... I'd place my bets on a short in the ignition switch or some wiring between the relays and the switch (which would be a bitch to trace).
Anyway, replaced the relays and the car hasn't been touched since then. Just tried and it fired right up, didn't even feel weak. Normally it would have been almost completely dead in that time frame. I'm really hoping the problem is fixed now. The car needs to be my DD again soon
-1994 Lincoln Town Car...always under construction
pop out the relay pack again and feel the relays. If they're not all hot and bothered... you're probably good.
shitty contacts inside the relay or at the socket will also make it hot. Its passing the compressor current through those contacts any time the AC is on. Sometimes the springs get weak inside the relays and it doesn't make solid contact. This one relies entirely on spring pressure to make the connection, it doesn't pull in like the others do.86 Lincoln Town Car (Galactica).
Well I haven't noticed the relays hot at all since replacing them. Maybe things are finally going in the right direction. The car has fired right up every time. I guess I need to let it sit for a few days and try again, that would be a true test.. Thanks to everyone that helped out
