Hi guys!
I notice that my ´87 Colony park (apparently) is leaking ATF from the Automatic transmission, and the drops are bigger and bigger
I leave you a picture where is leaking. I know is not the best image, but since I´m not in the US, I need to know if the problem could be a gasket and if you can help me to identify it to do the importation to my country, or any other recommendations from people with experience.
About the transmission oil (ATF), It looks clean and good, but since I don´t have the previous car history or any info about its maintenance I´m still doubtful about to change it, as I wrote on a previous post the myth says that the Automatic transmission will fail if I change the lubricant.
Thank you!
Thank you!
