I've been losing a little bit of coolant for a while, and it was not going into the oil, never any cross of oil in coolant or coolant in oil.
I have seen a little coolant on the ground by the rear of the engine and thought maybe one of the hoses going to the heater core was the issue, I felt around there and don't feel any moisture.
After having another starter fail yesterday, I noticed coolant along the top of the block/bottom of the passenger head.
Can the head gasket fail on the outer edge and leak coolant out there or is it coming from somewhere else and making its way to the outer edge of the head? The drivers side is perfectly dry.
