'04 GM eating A/C compressors like chocolate bars
    Clutch keeps going on A/C compressors. Replaced a couple years ago, replaced in May, replaced again in August, and now rattling again.
    I'm in Texas, so lots of highway cruising at 80-90 with the A/C cranked up. 4R70W with 3.27:1 rear axle. Do I need some sort of extra heavy duty A/C unit?
    '04 LS Premium
    Is it the compressor clacking or the clutch rattling? If the latter... just run it. If the former... yeah, might just be a crap lot. Might need to try an all-new or just get a refund on that one and get a Denso (what I did after the last replacement only lasted 2 years).
      If they aren't shimmed correctly it will wear rapidly. Unless its the bearing, in which case you need to use the AC more. The bearing does nothing when the compressor is engaged.
      If the AC is low on charge it will make the compressor cycle a lot, and thats not something you really want happening at high speed all the time. I
        Video for air gap checking;
        https://www.youtube.com/watch?v=v-nMDFvSjFk
        Alex.
          Turns out the rattling sound which I started this thread for was the radiator fan, which has been replaced.
          But then this morning the compressor blew again. All three failures (May, August, today) have been the same --> A/C stops blowing cold, then burning smell. It's not a question of lack of use, I'm running San Antonio-Austin-Houston so it's on constantly.
          That air gap video makes me jealous - would be that my compressor wasn't mounted on the *underside* of the engine.
          '04 LS Premium
            yeah thats not one of Ford's more easily accessed items. Sell point for the old 5.0, the compressor is right up on top.
              So you are burning up the clutch coil, not the the ac compressor itself from how you describe it. Once you verify that, you could see about changing that on car so you don't need to evacuate the a/c system.
