Page 1 of 9 123 ... LastLast
Results 1 to 20 of 161
Thread: Large Marge: The New Adventures
    Jan 2008
    New Jersey
    2,680
    Default Large Marge: The New Adventures
    As some of you may know, I recently bought the wagon known as Large Marge (an 89 Colony Park) off of Scott (lincolnmania). Technically my mom did, its her car, but I'll be doing all the work on it and using it as a driver and work vehicle! Anyway I wanted to start this thread to show all I'm doing to it, when I get more time later I'll make another post!
    +'82 Ford LTD-S Police Car. 351w, 2bbl 2150 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. 86 Valve Body Baumann Shift kit.
    +1989 Mercury Colony Park "Large Marge" Lopo 302. 3.55L K-Code Tow package, Baumann Shift Kit, Big brake swap, rear discs, HO intake/TB, custom exhaust.
    17,615
    Jealous.
    Wagons are the bees knees.
    Jan 2008
    New Jersey
    2,680
    Ok now that I have some time to write and post pictures... the original Large Marge RR thread can be found here: http://www.grandmarq.net/vb/showthre...ht=large+marge
    I've only been driving this wagon the past couple of days but I already love it...I'm not used to DDing a car with power and comfort features, my other two rides are base models. Here are some pictures of her as she sits now!
ID:	48292Click image for larger version.
ID:	48293Click image for larger version.
ID:	48294Click image for larger version.
    I've begun trying to bring the paint up the best I can with a clay bar, light compound (swirl remover), and cleaner wax. I plan on putting a more permanent coating on it to slow the clear coat failure down (see optimum gloss coat). It will look good overall for it's age when i'm done, I just hope to slow down the degradation of the paint, trim, and vinyl wood as best I can, using the best products I can.
    Now for the fun part. Improvements and upgrades!
    She runs and drives well as is, but there's always room for improvement. A list of things I intend to replace fairly soon:
    +Rear shocks (KYB GR-2's) and springs (wagon coils) (old ones have a spacer and are sedan coils)
    +Front shocks (KYB GR-2 police) (the one barfed all over the driveway, lol.
    +Big brake swap up front (scott supplied most of the parts needed)
    +New rear brakes and pads (I'm picky with my pad selection and the rear rotors are warped)
    +Valve Cover Gaskets
    +Rear tranny tailshaft seal
    +Drivers door lock actuator
    +tailgate window motor
    +sway bar bushing
    A few things I will probably address/upgrade in the future:
    +new rear 6X9 speakers
    +aluminum driveshaft
    +Baumann shift kit
    +rust removal and a bit of body work (not planning on a re-paint just want to halt the rust)
    Feb 2015
    3,110
    Transmission tail seal should be in the glove box already. I'd also highly suggest a new support bushing for the slip-yoke, since you'll be there anyways. Combine this work with the Baumann kit install, for minimal mess.
    Does she seem to have enough power and get-up-and-go for your needs?
    Jan 2008
    New Jersey
    2,680
    I saw the seal, and I actually ordered a new support bushing and seal for it anyway ($5 combo closeout!) although there doesn't seem to be any play at the yoke.
    She's got plenty of get-up and go, keeps up with traffic just fine. Classic LOPO doesnt have much up top, and better quality shifts would help too. You guys adjusted the AOD TV perfectly, it shifts right where it needs to.
    Do wagons have 20 gallon gas tanks like my LTD? It was half way between empty and 1/4 tank and it only took 10 gallons to fill it up.
    35,495
    i think they're 18. Possible the sender arm is a little tweaked. Some things have the super pessimist gauge, my car is completely the opposite. 1/2 tank is 10 gallons, E is "put on your walking shoes", but it takes 60 miles after a fill-up for the gauge to finally get down to F.
    Feb 2015
    3,110
    Yeah it's smaller than 20, not sure the exact number tho. Let's go with Gadget's suggestion for 18 gallons.
    4,404
    Glad large marge found a good home. Now it would seem that we are parallel in the universe somehow. Brown 82 sedans and burgundy later box wagons. Hmmm.
    Same experience on your fuel gauge is my 88. From 1/8 to over full on the gauge is 12-13 gallons for me. I have gotten 14 gallons in before on the low fuel light. The tank is fat up top, skinny in the middle, and fat at the bottom. I think it would run on e for a long time but I don't want to push luck with my original fuel pump. And I think it's 18.5 gallons in my Owners manual. Also some gas pumps that really throw out the volume will kick off before it's full.
    1988 Crown Vic Wagon - daily
    88 LTC nfldfordltd's Avatar
    Oct 2005
    Happy Valley-Goose Bay, Newfoundland and Labrador, Canada
    843
    The fuel gauges in the older boxes were always kinda wonky. The 87, 88 Fords and two 89 Mercurys I had years ago had fat tops and bottoms with skinny between F and E. The current Lincoln always had a really fat top, like the needle went waay up past F (perfectly vertical) and wouldn't come down to F until about 100 km (60 miles) of driving, then drop kinda fast, being pretty well empty after 300 km (200 miles) city or about 500 km (300 miles) highway.
    Now with the FUBAR sending unit, it stays waaay up past full in it's fully erect position until almost 300 km (200 miles) then falls flat on its face to E after a little bit of hunting around, at which time I need to find a gas pump NOW.
    And it hasn't been easy to find a sending unit for this car. 11 years of ownership, last three years of serious searching have come up with nothing. I *should* have changed the fuel tank to the single pump/sending unit type when I parted out a 92 Lincoln, those single sending units are a lot easier to obtain.
    And with your thread successfully jacked, I'm not normally a fan of wagons but I like that car. I think it's the colour that does it for me...burgundy always looked so regal on a Mercury.
    Enjoy the ride.
    Summer car-> 1988 Lincoln Town Car, triple blue, 267,xxx km. Out for 2017, new HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
    Winter vehicle-> 1996 Ford F-150 XL 4x4, orange, 302,xxx+km. AKA "King Billy". Takes the beating like no vehicle should ever have to. Bought 2013/11/26.
    Apr 2015
    Southern Commiefornia
    1,777
    That is a sexy beast and Newfie is right, the color really makes it. Hope she stays good for you and you get a lot of enjoyment out of her. Every time I see a nice wagon I get the bug for a while. Typically all the ones I see for sale are total beaters so it cures me.
    35,495
    Quote Originally Posted by nfldfordltd View Post
    Interesting. i always figured mine was screwed up but thats precisely how it behaves. Maybe its just a Lincoln thing. Same tank and sender as the other cars though so I don't know why it would be different unless the gauge itself is just different enough to affect it.
    4,404
    Edit previous post. Checked Owners manual and it's 18gal. Not that it's that much difference from 18.5. Never doubt the Gadget or HRG lol.
    35,495
    that was half guess from fuzzy memory of someone mentioning it in the past. I'm definitely not a walking wagon encyclopedia.
    Jan 2008
    New Jersey
    2,680
    It's probably tweaked. it went to F, and not a hair farther. My other cars it goes way past F. I drove it and it seems to go down faster than others too (the gauge that is).
    I replaced the rear coils, sits better now, the rear shocks were actually good (GAS-A-JUSTS), so i'll leave them in there. Another thing i'm going to add that i forgot to mention: Cats. The fumes are giving me a headache.
    Feb 2015
    3,110
    That's cause the rear shocks are recent, went on last year IIRC, at the time the rear discs happened. Side picture of car sitting on new coils pls?
    Nov 2014
    Evans, GA
    927
    My '87 is a bit like that. If there was an extra mark past 'F', that would be full. Takes about 60 miles of cruising to get it to the 'F' mark. By the time the low fuel light comes on, there's usually about 4 gallons remaining. Comes on around an 1/8th of a tank. My sending unit is a bit flaky from time to time. Once you get down past a half tank, sometimes the low fuel light comes on, but the needle stays constant, other times the light comes on and the needle stays just above 'E'. The really weird times the light comes on, needle falls, and then the light goes off. Sometimes I can fill the car up and it takes a bit of driving for it to pop back up and start reading.
    If it's doing the flaky thing for an extended period while I'm driving distance, I'll fill up at 250 miles. Usually that keeps me in a pretty safe area, however it hasn't gone stupid lately. Seems to operate better the more often it is driven.
    -1987 Grand Marquis Colony Park LS (320K Miles) - The Hideaway & April 2017 POTM Winner
    -1997 Grand Marquis LS (200K Miles) - The Daily Workhorse & March 2015 POTM Winner
    35,495
    the fuel light thing is probably more an issue with the low fuel indicator module than the sending unit. Its basically like a blinker stat inside. It has a long spring with a wire wrapped around it. Current flow between the sender and the gauge heats the wire and it keeps the contacts open. When the fuel level drops enough the current level reduces until the contacts no longer hold open and the light comes on. If those contacts get crusty it can stick and the light will be on all the time. Sometimes just unplugging the box and plugging it back in will fix that. It lives under the dash, basically above the gas pedal on the side of the heater floor ducts.
    Jan 2008
    New Jersey
    2,680
    Large Marge is pretty happy! Got a lot of work done to her this week.
    She now has new: upper and lower radiator hoses, bypass hose, heater core hose, thermostat, radiator cap, lower and upper intake gaskets, coolant, mobil 1 oil and filter.
    In addition she now has a mustang HO intake and TB on her. Thain has a lathe and for the price of some beer he was able to bore out the LOPO EGR spacer for me.
    Planning on putting on rear rotors today (old ones are warped), and 1" wheel spacers to make it look a bit more reasonable.
    Sep 2014
    Warren, MI
    4,532
    How does it feel with the HO intake and what not on it compared to before?
    I need to find a lopo spacer to send over to gadget.
    Jan 2008
    New Jersey
    2,680
    It definitely fattened up the torque curve in the higher RPMs. it would fall on it's face before, now it keeps pulling. Even though it may only be a 10 peak HP gain, the additional power all over is definitely worth it. Better throttle response too, not sure if that's simply because for the same amount you press on the peddle, you are letting more air in, or if it's the engine actually being more responsive, or both.
    After i did the rear brakes and spacers, i let the car down, and the REAR gas-adjust on the passenger side barfed all over the driveway. Ugh. So i'll be doing that sometime soon.
    It also has 3 codes now and the check engine light keeps coming on. 34, 41, 91.
    +34 EVP - (R) EGR did not respond properly during test EVR - (O, R, M) EVP sensor is/was high PFE - (O, R, M) PFE sensor is/was out of range
    and 41 and 91 are lean codes...hopefully related to the EGR and not to the HO intake swap. So guess I'll be getting another EGR valve (everything is connected, and the valve itself responds to vacuum)
    AND the parking brake ratcheting mechanism decided to no longer work. The parking brake can still be applied but it wont hold it. Anyone know whats up/any easy fixes?
    LAST problem i'll complain about. No heat. I flushed the heater core, it has excellent flow, I'm guessing it has something to do with the ATC sensor behind the glove compartment gadget was talking about in another thread. I have to try to find that.
