I'm not able to controls the windows using anything other than the master switch in the driver door. I replaced the master switch a year ago. I recall them working fine before the replacement. I did not try to use the other window switches until now. I believe that the replacement may not have been built correctly or is faulty. Of corse anything could be the problem. Does anyone have any information on the wiring? Can I bypass the child safety?
Power window switch.
If the window lock switch has a bad contact... that would do it since that cuts the power to the other windows.
