kishy's 1984 Town Car
    It took a looooong time for my 3G to take my yellow top Optima to 100%. I got "click" one day after it sat for 3 months (oopsie) and then boosted it. Blinkers were slow like the 2G days for about 1.5 hours of driving, mostly expressway with minimal load on system too, just low radio and A/C.
      The whine is probably alternator related. The caps on the dash speakers won't fix it. That filters out lows only. The radio might be the source, or it may be the amp in the trunk, or it might just be a crusty connection somewhere in the charging system or one of the ground leads. Either way its dirty power. Make sure the power and ground connections are clean, and if that doesn't help add a cap across the power input to the amp and/or the radio. I have a slight whine issue on the Conti too, and I can guarantee its not ignition noise on that one. I haven't rebuilt the radio or amp, so both probably have tired filter caps. I haven't done external caps either. Current plan is to hope both survive until this winter, then I'll give the electronics a rebuild.
        I thought that's all that cap did for the speakers. What type of cap to add on the power input?
          Something rated to 16 or 25V if getting a regular cap... and at least something about 2200 or 4700uF would probably work. Maybe 2 of them.
          Also... this may help: https://www.crutchfield.com/S-W9THWN...ion_guide.html
          It mentions checking grounds. If the radio is case grounded, it may help loads to strap a ring terminal to the body and run it to another ring terminal that's bolted to the case of the radio. I know this helped in the Mad Marquis as there is no ground to the connector and it grounds through the case and the support bracket that's bolted to the back of the radio. I had to make a ground wire to attach to.
            Let's not forget I removed the alternator noise cap...whether it'll help or not, I don't know, but I will re-integrate that and see what happens.
            Battery load tested "OK"ish. Not super great for its capacity but not weak in general. Will swing by the parts store it came from and have them test it. If it fails whatever voodoo they want to do to it, it will be replaced as I'm pretty sure it's still under warranty.
            These were the original door speakers...
            Current driver: Ranger
              JUNK. Those speaks even look poopy.
              Reminds me that the JBL's I gave you will sound "lower" due to them having a filter on them for highs, I believe anyway. That or they simply don't respond well to higher frequencies. Scratch all of that if they're the two way style as found in Mark VII's, those should respond to upper midrange & treble frequencies just fine. Your car is the only beast I've seen a difference in when swapping known good speakers in place of blown ones. Of course, you could probably just try to refoam your old ones if the voice coils are ok.
                Oil change last night @ 191,343km, accidentally about 1000km early once I found the last record of when I did it. Given that over 90% of my driving is short trips, I don't think it was a waste. It was heading for the S in 'SAFE' so consumption was starting to accelerate as it tends to when the oil ages.
                Sunday, my previously well-behaved parking brake release valve started doing that hissy thing they do. Slight tweaking of the shift lever would cure it. Yesterday it gave up and just started hissing all over the place. Popped a new one on today.
                That top screw is an absolute bastard. After spending far too much time upside down in my car trying to get that screw where it goes, I gave up. One screw will do.
                  Thats where I got to on the Conti, except that it moved out of position the first time I ran the gear selector through and the next time I tried it the tab on the column broke the slot on the switch that it engages so now the switch is ruined. Valve works, but it won't move with the shifter.
                    WHat a stupid design...
                    Then again, I imagine very few people had trouble with those during the warranty period or maybe even up to the 10 year mark.
                    It never hurts to change your oil early. I change it on the truck when it starts to burn oil, which is always right around 2,600 or 2,700 miles before I see anything missing on the stick. I couldn't imagine going to 6 or 8k on that oil as like you said, it's obvious the oil is aging so it can't be lubricating as well as it was. Or maybe it is lubricating too well and thus getting past the rings and stem seals?
                      No damage to mine. I was careful to make sure the 'arc' of its travel was correct though...the top screw hole is lined up, just absent of a screw. I can see how damage would happen if the alignment was off though, because you've got some great leverage with that shift lever against such a tiny little plastic thing.
                      I mean...they seem to make it 20 or so years before the average owner sees a problem, and in this case, 34. Considering it consists of a piece of rubber that sacrificially slides against a piece of plastic under vacuum, yes, it lasted just fine. If it was a more serviceable part, every year one could add some grease on the sliding surface and keep it good forever, but you just can't really get inside these things. You can see traces of rubber debris in mine where it has degraded through use, and there's grease in the new one, which slides much easier. I just wish it was easier to get access to. It may be easier if the column is dropped.
                      The design is essentially the same as that of the Mark VI headlight switch so it doesn't surprise me they came about at the same time. E1 part number though, on a part that was in use since 79. I do wonder what design improvement they came up with 2 years into its existence.
                      The 90+ valve is simultaneously both more and less of a pain in the ass. More because the column must be dropped to get to it (it lives on top), and more because it can't be bought new, but less because it's super duper easy to get out from the driver seat once the column is down.
                        Wow, I did not know that about the '90+ column.
                          ... the top screw hole is lined up, just absent of a screw. I can see how damage would happen if the alignment was off though, because you've got some great leverage with that shift lever against such a tiny little plastic thing. ...
                          One possibility to prevent too much movement is to use a piece or two of relatively soft metal (like a piece of coat hanger) that will fit in the screw hole and can be bent to stay put.
                            l remember when i removed mine just to get the stupid thing out of the car....makes me wish I just left it because it was a royal pain.
                              Interesting note about the parking brake release valve...the shifter glides so smoothly through its travel now that I keep overshooting OD and landing in D. Much lower effort compared to forcing an unlubricated rubber thing around in a high-friction situation.
                              Cough, ahem. Anyway, yes. New valve works well (or should I say Wells) and I'll probably put the second screw in sometime when I feel like sacrificing my spine.
                                ...forcing an unlubricated rubber thing around in a high-friction situation...
