Page 15 of 17 FirstFirst ... 51314151617 LastLast
Results 281 to 300 of 329
Thread: kishy's 1985 Ranger
  1. #281
    all the CFI are belong to me
    Feb 2014
    Windsor, ON
    1,747
    I was planning to shove some relays in that box, but then the intent behind the box changed when I realized I had so little usable wire on the truck. As you can see there's no room in there now. Breaking the trailer stuff out into a second box containing some relays is a future idea, but it'll do for now. I was going to run a good size battery positive wire to the back and then have rear-mounted power distribution to allow for easily lighting the bed and maybe some reverse flood lighting under the bumper (the same feed could be used for the relay switched side for trailer lights) but that will come later.
    Any trailer I own is going to have LED lighting to be less of a burden in that way, so probably a non-issue.
    I haven't gotten that far in planning for the Lincoln yet. Relays are always good but if the lamps are LED it matters a lot less.
    83 GM 2dr POTM 10/2019 | 84 TC POTM 1/2017 & 4/2019 | 85 CS | 85 Ranger | 91 GM POTM 12/2017 | Junkyards
    Gone: 97CV | 83 TC
  2. #282
    39,259
    LED lighting mostly makes all of that not an issue. Standard lights with thermal blinkers are where you have trouble. Add load and you get the rapid flash thing going on. THat and the extra load on the marginal light switches doesn't help.
  3. #283
    Feb 2014
    Windsor, ON
    1,747
    Today, I installed Air Lift Ride Control kit 59516 on the Ranger. This should eliminate sag when pushing the cargo capacity.
    Install was straightforward. I'm going with manual inflation valves for now and if I find they really help on a frequent enough basis I may look at an automated compressor system. I have them plumbed independently with the fill valves in the wheel wells.
    I also brought the idle speed down. It was around 1000, and is now around 600. I'm not sure what's "correct" for this engine but that's about as low as it can be before the charging voltage starts to drop, so that's the minimum I want it at. Should make creeping along in traffic a lot easier though.
    I picked up the Harbor Freight LED vehicle tow light set (magnetic mount to stick on a vehicle in-tow). These were able to prove I wired the trailer connector correctly, and can also be used as needed on my cargo carrier or bike rack.
    Gone: 97CV | 83 TC
  4. #284
    39,259
    most things have a hot idle in the 600-700 range. Too low and its prone to stalling and charging issues, too high and it either bangs with an auto or you ride the clutch too much with a stick.
  5. #285
    Feb 2014
    Windsor, ON
    1,747
    I did bring the idle back up to around 750 warm. I think I need to teach the computer something-something, but not quite sure exactly what, as the IAC does not take over no matter how low I bring it down. However the IAC does work because when the engine is cold started it holds about 1500RPM idle speed for a minute or so.
    I applied a new sticker to the Ranger, since my employment is more or less solidified now:
    Found that the exhaust hanger (same one as used on the Lincoln) has failed (in the same way as the same ones did on the Lincoln). Most concerningly is the fact that the factory hangers were still load bearing and are located just inches apart from this one; it was only there to reduce noise from some effects that are hard to coherently put into written words. So that settles that, do not buy Walker 35600 hangers for any type of use whatsoever, as they are garbage. A proper solution here involves replacing the midpipe and muffler, and I'll probably just end up doing that as my patience for these self-engineered hackjob repairs is thinning. This hanger was only on for a very short time, I think I put it on when I installed the hitch.
    https://i.imgur.com/6atiFGC.jpg
    https://i.imgur.com/2c2QIyI.jpg
    The air suspension has been holding pressure and has done wonders for the handling. This truck has a tendency to do a weird sideways hop going over certain bumps, and that is almost entirely cleaned up by a little air in the back. Next step will probably be some shocks that don't suck. I also have a front sway bar waiting for me from a guy on a Ranger forum so that's going to do wonders as well.
    Gone: 97CV | 83 TC
  6. #286
    Member BigMerc96's Avatar
    Jun 2011
    I can see Detroit from here
    517
    Yeah, the side hop from a solid axle vehicle will be reduced by firming up the rear suspension, and knowing you the shocks in that truck are from 1985.
    That is one of the biggest differences in my Townie after it lost its rear sway bar, it wants to hop all over in some situations (NB I75 at Big Beaver curve comes to mind). Even on a FWD car, too soft of a shock can cause the ass-end to want to jump around. The '11-'16 Elantra is bad for that, they are a twist-beam rear and they hop all over the place in US spec. Apparently the USDM cars got softer rear shocks to give them a softer ride, swapping in firmer shocks is supposed to fix it. If my Mom wasn't leasing the '16 Elantra she had, I would have ripped out the front shocks before it had 5k miles on it. Drove me nuts. Her's had 17" wheels with lower profile tires, I can't imagine how bad a base model one musta been with 15" wheels. She had a redesigned '17 Elantra as a rental and they almost totally fixed that, it was the single biggest difference while driving it.
    -Steve
  7. #287
    Feb 2014
    Windsor, ON
    1,747
    Quote Originally Posted by BigMerc96 View Post
    I'll have you know they're from 2015, sir. And they aren't even bargain basement RockAuto wholesale closeouts either...they're Monroes purchased retail from Advance. However, they were garbage when new and still are today, so that's not saying much. I think they have a lifetime warranty but if the replacements will also be junk then I don't see the value in swapping them out. Rust in my eyes for no reason.
    I've had the hop in the Panthers too, but generally only on extremely aggressive and repeated bumps, like a few potholes spaced just right relative to the wheelbase that the car can't settle again between bumps. The Ranger will get shaky after just a single significant bump. But the lack of sway bar, soft springs, and low-functioning shocks all come together to multiply the effect.
    Gone: 97CV | 83 TC
  8. #288
    5,667
    I once found a Gen 1 Ranger in the junkyard that was an old U-Haul truck. Huge front and rear sway bars. Just in case you come across one...
    1988 Crown Vic Wagon - daily
  9. #289
    Feb 2014
    Windsor, ON
    1,747
    Ranger Marti report:
    Gone: 97CV | 83 TC
  10. #290
    Sep 2014
    Warren, MI
    5,876
    WHoever ordered that had priorities; I don't need no stinkin' radio! Give me power brakes though.
  11. #291
    39,259
    Its funny that no radio was an option. What was standard, just AM/FM ? or would that have been AM-only? There is actually an electronic AM-only radio. I have no idea why this exists, but I have docs for it in my radio service manuals.
  12. #292
    Nov 2006
    Dirty Jersey Yo!
    7,968
    Putter Project has no radio or air conditioning. Strictly a work truck. I guess there was no playing around in the early '80s LOL
  13. #293
    5,667
    28 days late...apparently the 2.0 wasn’t the only slow thing with that truck.
  14. #294
    Sep 2014
    Warren, MI
    5,876
    Probably just AM. I've seen GMT400 trucks like I've got in stripper form with AM only radios, knobs and all. I went to nab one from a junkyard several months ago for posterity but the shit in the wheelbarrow shifted and killed it..
  15. #295
    Feb 2014
    Windsor, ON
    1,747
    I have been in an early 80s Club Wagon (which I suppose is probably an extended length E-250 with the passenger goodies) which had an AM-only radio with electronic tuning. I also have no idea why it exists. That was probably base for a Ranger as well. The guy did put in a radio, and he was the original owner, and the one he put in was period correct for the truck...it's entirely possible he reasoned that the added cost to upgrade to FM was more than the off-the-shelf price to buy an aftermarket unit.
    Newest update for the Ranger is a fun one. Pulled the trans today. It seems to need an input shaft bearing (mild noise when off the clutch pedal, and it does wiggle slightly), and I'm going to have my buddy with the machine shop try to resolve the fluid loss issues out the extension housing. I like to run Redline MT-90 which is not really cheap, and this trans likes to piss a little everywhere it goes, so hopefully I can get that taken care of. Replacing the seal did nothing for it previously.
    I would probably consider swapping to a M5OD, but there are some dumb things involved with that, like finding the correct clutch line (TK5 slave input is clocked around 11:00 from the back, while M5OD is from about 9:00, which is also why the M5OD is notoriously awful to bleed the clutch on), and the driveshaft length might be different, and as silly as it is I don't like the M5OD shift levers.
    Gone: 97CV | 83 TC
  16. #296
    39,259
    Make sure the yoke on the driveshaft is in good shape. If that has a groove worn in it, the seal won't actually seal. Worth checking the output shaft bushing too.
    I am sort of curious what the cost-add for AM radio vs AM/FM was over no radio. Probably is more than a basic aftermarket radio and speaker package would have cost, and its not like the OE stereo was anything impressive.
  17. #297
    Sep 2014
    Warren, MI
    5,876
    AM radio as base equipment existed so they could charge a premium for FM and above.
  18. #298
    GMN Regular Giraffe's Avatar
    Jan 2016
    Cabot, AR
    876
    The '89 Aerostar XL my parents bought new had an AM radio with electronic tuning. I miss the old days.
    óJohn
  19. #299
    39,259
    I get the upgrade thing, but I don't get why they paid to develop a digital one when they had a conventional analog AM already.
  20. #300
    39,259
