Right? Couple of very clean cars there. That '90 is gorgeous! Body is better than mine for god's sake.
Just picked up an 84 LTD CV Wagon
Originally posted by knucklehead0202 View PostRight? Couple of very clean cars there. That '90 is gorgeous! Body is better than mine for god's sake.1985 LTD Crown Victoria - SOLD
Not impressed with the Lincoln Grenada or the Cadillac Caprice? Those were the precedent for such awesome things as the Cateract Cavalier or the Lincoln Taurus.86 Lincoln Town Car (Galactica).
The Seville was actually based on the Nova... I didn’t mind those too much.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Jealousy overwhelms my soul as I view your mint tailgate cable... just kidding... kind of. Can you get some measurements when you get a chance?1990 Country Squire - weekend cruiser, next project
The NOS cable I have,(NOT for sale) is 17 1/8" center of eyelet to center of eyelet. 1/2" hole on one end, 3/8" hole on the other. Hope this helps you find a new one. WagonMan89 Colony Park
90 Colony Park
70 HEMI Daytona Convertible
I think you can use some 3-in-1 oil on the plastic coating. Just give it a light rub and wipe up the excess. In a few days, if it's not limber enough, give it another rub. It should be set by the end of the week.
That 90 in the JY is the gift that keeps on giving.
I noticed the door glass felt channel on mine was dry and cracked all to hell so I grabbed both front door ones.
Is the rear glass that goes up and down the same or is both that and the fixed glass different? I'd guess just the fixed glass is different between the sedan and wagon.
Tiggie, to answer the mileage question:
I hope that's 122k because only 22k would be a major shame.
My 89 Colony Park had the same problem when I bought it. Ended up being the ground wire was not grounded properly under the dash. Try using a jump wire to get a solid ground and see if it works. WagonMan89 Colony Park
90 Colony Park
Originally posted by WagonMan View PostMy 89 Colony Park had the same problem when I bought it. Ended up being the ground wire was not grounded properly under the dash. Try using a jump wire to get a solid ground and see if it works. WagonMan
That makes total sense since that switch is the same as the driver window switches (identical) and when the window switch is in neutral position the power passes through. Each switch gets it’s ground locally.
I love my Squire, but if I could find a similar-condition steel-side I'd swap in a heartbeat.'91 LTD Country Squire LX | '82 Cougar GS wagon |'03 Marauder | ' 18 Flex Limited EB
formerly: '02 MGM, '04 MGM, '04 MGM v2.0, '04 MM, '07 P71 w/5-speed, '03 SAP P71, '04 CVLX (now in pantera77's stable), '10 P7B
