I know it’s on here some where but can’t find it. After getting my new (to me) rear swaybar which does make a difference, the front seams like it need more help. Which front swaybar do I need the wagon or the pi one. I think I seen the wagon ones were better but not sure. And which years do I look for or do anyone of y’all have one for sale. Thanks in advance
Bigger front swaybar
Either will do, the wagon has a larger diameter but is hollow, where as the police is slightly less and solid. 79-91 box's will work, the challenge will be finding either one of them.-Phil
Wagon one is preferred to the police one because it's lighter, but other than that... What he said^^
You can also go after market. Addco makes one for the 92 and up cars I believe but is designed to utilize the same end links as the boxes do. Its BIG bucks and is a smidge too wide so it rubs tires on full lock.~David~
The wagon part is also more available, so it has that going for it over the PI part.86 Lincoln Town Car (Galactica).
Yes, but if you want to be certain they should measure 1 3/16" in diameter-Phil
No, I just simply don't know, and it always helps to check-Phil
Is there any particular reason you can't use the '92-'02 sway bars? We know they fit when doing the big brake swap, and we know they work with box style end links on a aero/whale since they retained the mounting holes in the lower control arms. There are at least a few '92-'02 owners out there using box end links with the stock front bars. Just a curiosity question. If they work then that would greatly expand the sway bar options for the box platform since '92-'02 cars are more common and have solid sway bars ranging from 25mm-29.5mm depending on application. I currently have a '98-'02 P71 (29.5mm) front bar and no rear bar on my '97 Town Car after the rear bar mounts rotted off the frame, it still handles better than it did with the stock 26mm front and 17mm rear.-Steve
The newer cars use a different style sway bar end link. It mounts to the top of the spindle near the ball joint. However:
The lower control arm mounting hole for the box-style sway bar end link is still present on newer control arms, so even if you replace the lower control arms entirely, if they still have the holes for the old style end links, you will be able to use the old style end links.
Edit, Whoops. BigMerc96 already said this above.
Originally posted by Elias View PostI don’t get what bigmerc was saying. So the 98-02 swaybar would be even better than the wagon one-Steve
