I have, what a surprise, a good, new brush, clocked 3g in Yonkers. It might be long ears though. I have the long (police?) bracket which is hard to find.
03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice 02 SL500 Silver Arrow 08 TC Signature Limited, HID's Mods>235/55-17 Z rated BFG G-Force Comp-2 A/S Plus, Addco 1" rear Sway, Posi Carrier, Compustar Remote Start, floor liners, trunk organizer, Two part Sun Visors, B&M Trans drain Plug, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17 12 Escape Limited V6 AWD, 225/65R17 Vredestein Quatrac Pro, Winter 235/70-16 Conti Viking Contact7 Mods>Beamtech LED headlight bulbs, Husky floor liners
If its that part, go later in the day to your friendly local autoparts store and ask to look at some alternator cores "for research". You'll probably come across a good one of them on a core somewhere. If you ask, they'll probably let you have it. I've done that for customers before. Its a removable part, just bolts on.
-Steve
2006 Audi A6 S-Line FWD ~132k miles, stock. 1998 Mercury Grand Marquis LS HPP ~102k miles, slowly acquiring modifications. 1997 Lincoln Town Car Cartier ~145k miles, Ported Plenum, Gutted Airbox, Mechanical Fan Delete, Contour E-fan Retrofit, Dual exhaust, Cats ran away, KYB Gas-A-Justs, P71 front sway bar, air ride reinstalled, Blinker Mod, Projector headlight retrofit, Caddy 4-note horn retrofit, Wood rim steering wheel, rustbelt diet plan.. 1996 Mercury Grand Marquis GS 117,485mi. R.I.P. 7/14/12
Measure that shit! I'm due for a new rotor in my diesel's 3G, one of the brush races (slip rings) was very grooved some 5000 miles ago, and now the stupid thing is wicked loud. I need 8.25" bolt center spacing on the front half of the case, tho ultimately that's of little importance since I can re-case and re-clock these in my sleep pretty much, just having the proper front half will make the job a bit easier...
That's not very commonly found on the 3G conversions, tho I suppose it depends on what application the alternator was intended for. The Mustang alt doesn't have that, heck if I remember if the Tortoise one has it or not and I'm too lazy to walk outside and check, lol
OEM they where used on the taurus 3G, I left mine on when I did the conversion, made it an easier access point. Check underhood of the front drive cars, they seem to be most common.
If you broke the stud coming out of the alternator, you;ll need to tear it down to replace the stud.
Well. Its not just a nut and bolt holding the assembly to the rectifier. There is a stud pressed into the assembly, the same stud I accidentally shortened by gorilla'n it, and surprisingly my fix involved shortening it even more!
Once the back half of the alternator is removed (make sure to remove voltage regulator first) you will find a rather long nut bolted to the same stud I wrecked. I basically chopped down the existing stud to about half the lenght so that large nut that threads on has about half the nut empty for a bolt to now thread into it.
I'll put some electrical schmoo in there when I tighten the voltage sense wire and charge cable to her. Worth a shot versus purchasing a new one.
Here you can see the one large piece that I ripped off then the two smaller precise cuts I did with a dremel. You can also see the new bolt that will hold the charge cables in place.
Yep, pressed in, I remember now that Dave jogged my memory. I couldn't remember why I didn't bother fixing mine other than I had another brand new alt for the other car that i stole (and still haven't gotten the 3g conversion done on that one). I'll have to revisit mine and see if mine broke in a way that would allow for the same fix since that alt was also only a year or two old before I broke it.
