Looking for 80s Townie or Conti keypad. It goes into the dew wipe trim on the driver's door. Same part on both vehicles as far as I can tell. Should be able to use 80-89 Towncar or 82-87 Continental. I'll take the whole trim piece if thats easier for you, but the keypad is held in with two spring clips that pry right out. Needs to look halfass presentable, so somewhat legible numbers, not cracked and split open, and the buttons need to feel like they work. Understand if its not able to be tested but if the buttons don't even seem to click when pushed I probably can't do anything with it.
for the yard shoppers, both Continental and Towncar door dew wipe trim pieces come out fairly easy. There is an acorn nut at the rear edge of the door on both, and a phillips head up in the smoker window area. Remove both, pry straight up on the trim to pop it up out of the door. Same method on both cars. The cable fishes down and around under the glass mechanism and should plug into the rest of the car harness near where the window motor and all the other stuff plugs in.
