Anyone know what fittings to use for trans cooler line from trans to radiator? Do bot
    1988 Grand Marquis
    Sent from my iPad using Tapatalk
    1988 MGM
    Dorman 47144 or 800608 should be it. Seems to be the same part.
      Gadget are those at the transmission? I am needing the ones at the transmission for my 84 Town car.
      Tim
      2000 Ford Crown Victoria
      89 Lincoln town car: RIP
      1990 Mercury Grand Marquis LS
        Yes, same at both ends if you have the quick connects.
          My car doesn't have them. any other ones that will fit?
          Tim
            If you don't have quick connects, they should be a standard flare end on the line, and the trans itself will have an NPT to flare adapter threaded into it. I think its 1/4 NPT male to 5/16" flare but measure the trans line to confirm the size.
              I picked up the Haden adapter which was the correct size. But didn't go in far enough to seal. The flare is about 1/2 from the end of the fitting. I hope it makes sense.
              Thanks for the help.
              Tim
                I did some checking and found the Hayden fittings for a 94 Crown Vic is the proper fit. Hayden part #394.
                Tim
