Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
Thread: ABS light on help needed
  1. #41
    35,850
    maybe this will be of help
    Attached Files Attached Files
  2. #42
    35,850
    also this1095 troubleshooting.pdf
    courtesy Alldata but I'm pretty sure this is straight out of the Ford factory manuals.
  3. #43
    35,850
    and the last bit of it, the wiring diagrams for the system
  4. #44
    Mar 2010
    Lewisville, TX
    19,969
    Yes, it is. It's a few pages of the 25 page one I posted in the rant thread.
  5. #45
    Member EaOutlaw1969's Avatar
    Feb 2018
    252
    Thanks that is the one i was thinking it was and it is one of the connectors i was calling a dead end since the connector is just a looped wire
    and thanks for the attachments and help. the guy from Mitchell sent me what seems like 40 - 50 pages or more which may be enough to diagnose my issue.
    last night I was seeing red from the absolute incorrect and incomplete information on Mitchells website and what got me even madder was the lack of a simple appology.
    I looked over the pin point test for c1095 at least now i actually can test some of the system, Some of it I will have to take a leap of faith because the lack of a Ford tester yet now that i have circuit information and wire colors with the pin point test and wiring diagrams I stand a chance figuring it out.
    It is strange how even Alldata ( copy of Ford ) shows a Brown wire at the ABS Pump Motor yet the wires at the motor are thick and black ( both sides ) At least Alldata shows the connector in a diagram so you know which one get + and which one gets - to test the Motor.
    I will rerun that test both on my old on car ABS motor and the off car ABS motor and compare noises I have a feeling since my car sat for so with crappy brake fluid that maybe one or more of the parts inside the ABS manifold is stuck because when I manually operated the Motor yesturday it sounded like crap.
    Thanks again for the help
    i will also check the Evac and fill connector for corrsion now I know for sure which one it is.
    2000 MGM LS Palm Beach Edition a work in progress
