Evolving Wagon Plans
    The Quarterhorse can do I think 4 programs if you wire up the selector. I think it can switch on the fly too.
    The spacer is more useful for heat insulation than anything else. It helps keep the upper from heat soaking so the air charge is cooler. The runner length change probably doesn't affect things all that much. You'll need at least a 3/8 spacer to clear the fuel rail anyway.
      don't think the 1" spacer is gonna clear a grand marquis hood. 1/2" probably.
        Uhh, guys... I found a used mustang turbo kit for $300, only thing missing is the intercooler, apparently. https://columbus.craigslist.org/pts/...816007086.html
          Remember... you do want to actually drive this right? Project creep is a real thing.
            A supercharger would be better. More low end torque. Turbo lag is a thing, especially if the turbo isn't properly sized. Turbos are also prone to bearing failure if the oil supply isn't right. Run them dry or dirty and the bearings wipe out, then you're SOL. A wiggle test on the turbine shaft will usually tell you enough about it to make a judgement but if its way too cheap its probably for a reason.
              Here's some beefy injectors (which I think fit) and a lot of parts that don't, but somebody here might be able to use. There's an ON3 turbo kit for a 2V 4.6 pretty cheap if anyone is interested, guy says "needs waste gate(s)" but I don't know/don't think it comes with the turbo either. https://columbus.craigslist.org/pts/...802476483.html
                probably means blow off valve. Most turbos have an internal wastegate, but the BOV is needed to keep the turbo from beating the crap out of itself every time you shut the throttle after a pull. Unless he means the actuator, thats external. The wastegate is a flappy thing inside the turbine (exhaust side) housing. Basically as it opens, it lets exhaust bypass the turbine in order to control boost pressure.
                  I would stay the naturally aspirated route. A turbo system is going to be a significant amount of work, with the risk of reliability issues.
                  I am currently in the planning stages of a push-rod 302 for my '90 LX. I wanted to do a Coyote swap, but at the end of the day even though the engine is cheap, the rest of the swap is not.
                  I have looked at a number of OTS cam grinds, and I had at one time actually settled on the Anderson N41 (mine is not a fuel mileage build). However, a custom ground cam from Ed Curtis (FlowTech Induction) is only $400. Given the nature of your build, I would definitely say that is your best option. A little more expensive, but if the performance and especially drive-ability is even marginally better, an additional $70-$150 is a small price to pay.
                    Found some used BBK headers (probably the 1515s) for $125, I know they're hit or miss with the GT40P heads, but hopefully I'll be getting the AFR heads put on. Think I should just go ahead & pick these up?
                    I'm debating whether or not to have the bottom end checked/refreshed on whatever motor I get, and having the rings done too when the heads get put on.
                    What's a decent ballpark price for an engine rebuild? Are there any shortcuts? Like I found this 302 roller block already 30-over to build a 306 for $300. https://cleveland.craigslist.org/pts...822096711.html
                    Vs getting a block for $50-100 https://columbus.craigslist.org/pts/...811944310.html
                    Obviously there are going to be some costs to get things checked out to make sure the motor is worth building. I'm going to try to talk to a couple machine shops here and see how much a build would run. I know short blocks are like $2300 from summit.
                    I mean it would probably be cheaper and easier just to get the Explorer motor and have a machine shop out in PA slap the heads and intake on with a cam, and trust that the bottom end is going to hold up.
                      Like a machine shop rebuild? You're looking at about 700-1100 bucks or more depending on what all you're having the machine shop do. I had the block bored, a few broken bolts extracted, rotating assembly installed, cam installed and degreed, brass core plugs, etc. With parts and whatnot I think I paid 900. I installed the heads, timing cover, water pump, oil pump, oil pan and whatnot myself.
                        i have a short block in the shed that the tree fell on if we go the rebuild route.
                          Got the shorty headers for $100 & the guy threw in Ford Racing valve covers for $40 more. I see no interface for posting pics but they're matte black with red Ford symbol and Ford Racing text. I hope they fit/work. https://twitter.com/SexCpotatoes/status/1101624040970772480
                            Found a 351W the guy claims is a "factory rebuild." haven't called yet to find out the story. I know the AFR 1402 heads will fit a 351, just don't know if I would need to look for different intakes or whatever, if the budget allowed a jump to that.
                            https://akroncanton.craigslist.org/p...829706191.html
                              Now I'm wondering what injectors to go with, as I'm seeing some 42lb flow-matched injectors on ebay for like $59 (I don't know if they fit the motor). Because I googled the part number of some 30lb injectors I found on CL used for $150, apparently they've got refurb 30 lb sets cheaper than that including shipping.
                                Go big with injectors. Biggest you can afford. You settle out the rest in the tune. You will always have enough injector for future upgrades then.
