Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 108
Thread: Evolving Wagon Plans
  1. #81
    Jan 2007
    Westmont, New Jersey
    10,258
    97 had egr passages. The 98 was the maybe year.
    "Vicky" 1986 Ford LTD Crown Victoria LX ..................................."Blue" 1992 Mercury Grand Marquis LS
    Vicky
    Too much stuff to list in my signature...
    Blue
    Gone! But Parts from it will live on in others!
  2. #82
    BANNED! sxcpotatoes's Avatar
    Jan 2008
    Northeast Ohio
    2,737
    Quote Originally Posted by 86VickyLX View Post
    Thanks! Sent my dad after the part the other day, and he tossed it in the shed. I have to figure out prepping it for shipping, but haven't looked at it yet. I'll keep the EGR if it's there, for + cruising economy.
    Called and talked to Dave about the 351, but probably going to pass, same potential big intake or fuel injection conversion costs etc, though the oil pan's already right for our cars.
  3. #83
    Sep 2008
    Whitestone, NY
    18,452
    I’ve shipped a lower intake to tmoss for port work before.
    With anything I ship out I try to make it at least 20 foot drop test proof. Lol. Thick cardboard box with extra cardboard inside to protect it as well as lots of bubble wrap. Everything survived just fine. I got mine blasted and painted by him as well. It came out nice.
  4. #84
    37,506
    I shipped one to him as well. I think I zip tied it to a scrap of wood to keep it from moving around too much in the box and reinforced the box with corner boards from work. they're basically cardboard angle iron, good stuff if you want to beef up a box.
  5. #85
    Mar 2010
    Lewisville, TX
    20,897
    Love me some cardboard angle irons for shipping stuff.
  6. #86
    Jan 2008
    Northeast Ohio
    2,737
    The head mount bushings, 1/2" phenolic spacer, battery to switch cable and switch to starter cable, motor mounts, permadry valve cover gaskets and oil pan gasket should all be at Scott's by now.
    I have a new cap & rotor, wires (but no plugs yet). Also have the 3g ALT, HD water pump, double roller timing gears and chain, as well as power steering pump/reservoir. I ordered the 2 belts and radiator hoses the other day.
    Anyone have any suggestions for EGR, oil sender, thermostat, water pump and other gaskets? I don't know which head gaskets to order, because different thickness can change the compression ratio. Didn't know if there were certain brands to avoid or anything. There are a couple part number suggestions mentioned on the AFR 1402 head product pages for head gaskets to use.
    I still need to get a MAF & injectors (there's this set on CL for $225 that would be about an hour drive https://cleveland.craigslist.org/pts...854210095.html ). Or there's a super pricey option of IDI1000 injectors for $800 obo https://akroncanton.craigslist.org/p...848720638.html
  7. #87
    37,506
    no "calibrated" MAF. You want a normal Ford one, the tune will take care of whatever size injectors you go with.
  8. #88
    Jan 2008
    Northeast Ohio
    2,737
    It's probably going out tomorrow, ended up putting a second layer of cardboard in the box, wrapped in bubble wrap, then corner reinforcement at all 4 corners, also along the sides of the intake, and at the top diagonally in the box. Going to wrap it in gorilla tape so it all holds for sure.
  9. #89
    Jan 2008
    Northeast Ohio
    2,737
    I did find a set of 39lb Cobra 4.6 injectors offered on CL but I don't know if they use a different plug end and would need a set of adapters @ $100+. Does anybody happen have a helpful list of what vehicles came from ford with the red top (30lb) or bigger injectors so I can use those to search for new or replacement ones?
  10. #90
    Jan 2008
    Northeast Ohio
    2,737
    Okay, found this good guide on injector sizing, plug style, etc, and potential HP limits on each size of injector both naturally aspirated and forced induction. https://lmr.com/products/mustang-fue...tor-size-chart
  11. #91
    Domestic Tourist Lincolnmania's Avatar
    Sep 2004
    Birdsboro PA.
    17,146
    yea i'm running out of room for parts lol.
    did you buy a lightning egr spacer yet? i think david had a bored out one for sale.
    i usually get the small stuff at autozone. never had any luck ordering belts or gaskets online.
  12. #92
    Mar 2006
    Bedford, VA
    4,981
    I think 1989+ Thunderbirds with the 3.8 Supercharged ran a 30-lb injector. Not exactly common junkyard stuff though.
    1988 Crown Vic Wagon - daily
  13. #93
    Jan 2008
    Northeast Ohio
    2,737
    Scott, apparently the spacer and throttle body is a 65mm for an Explorer, and in researching the Cobra intake, apparently the EGR spacer part is integrated into the upper manifold. So I only need a throttle body.
    There's 2 polished aluminum Summit Racing options, one on clearance for $120. https://www.summitracing.com/int/par...ng?prefilter=1 The other is $165 https://www.summitracing.com/int/par.../model/mustang
    Or there's a BBK throttle body for $175-200, but I'd rather save some money if one of the cheaper options will work just fine. Any comments or suggestions on what to go with?
    May have to spring for the Accufab, if I can find one for under $300, I dunno https://www.stangnet.com/mustang-for...-bodys.410277/
  14. #94
    37,506
    Sexy John is running a Cobra intake, you can confirm with him but I believe no EGR spacer is correct.
  15. #95
    Jan 2008
    Northeast Ohio
    2,737
    absolutely, EGR thingymajobber is cast into the intake already and no need for any spacers, sorry I didn't link one of the threads where I found that out http://forums.mustangworks.com/f8/co...e-spacer-2859/
  16. #96
    Sep 2004
    Birdsboro PA.
    17,146
    can the aftermarket throttle body be modified? that's the question. won't bolt on to a panther.
  17. #97
    Jan 2008
    Northeast Ohio
    2,737
    I found this old thread about a Summit 70mm TB with a removable bellcrank? so you can flip it? I don't know what part number the guy was looking at, I PM'ed him to see if he ended up using that TB. http://www.grandmarq.net/vb/showthre...+throttle+body
  18. #98
    I post a lot...
    Dec 2011
    Yonkers NY
    3,862
    Not sure if this is relevant to Scott's question but a markr VII cable means you do not need to reverse the linkage.
  19. #99
    37,506
    Mark VII and Mustang stuff is effectively the same. Cables end up doing the reach-around, and of course they'd need to be swapped for longer ones in order to do that. I think John has some custom made throttle cable adapter to make his stock cables work. I don't know what he's using for a throttle body but I don't think its a stock Ford item.
  20. #100
    I post a lot...
    Dec 2011
    Yonkers NY
    3,862
    The 89 mark Vii doner car that supplied the engine for my old 89 supplied the cables which reached around without any extensions.
