Results 1 to 18 of 18
Thread: Is there a 20amp fuse in location 32 on a 2000 mercury grand marquis?
    Member EaOutlaw1969's Avatar
    Feb 2018
    339
    Default Is there a 20amp fuse in location 32 on a 2000 mercury grand marquis?
    I am on a wild goose chase curtesy of Mitchell on demand diy.
    I have been trying to step back and recheck the basics for my ABS issue Mitchell shows to check 3 fuses
    First one is supposed to be a 10 amp fuse in number 14 spot under the dash
    My car seems to have a metal circuit breaker perhaps a 10amp I did not look that close but I did confirm power to it and checked with a meter that it is not stuck open.
    Next fuse they show is the 20amp that is supposed to live in spot 32 at what they call the central junction panel ( I am guessing they are talking about the under dash fuse panel )
    Third is the main fuse ( Maxi type for the ABS ) in the panel near the battery fuse 15 they show it is supposed to be a 40 amp my owners manual and the car has it as a 50 amp
    The fuse panel near the column only goes up to 18 so where the hell is this fuse 32 coming from
    I looked in the owners manual and under the dash and under the hood the only other fuses that I know of are fusible links near the battery. So what gives is Mitchell ON demand diy complete crap or should I consider never working on a car again if I can’t find a damn fuse.
    I have found many discrepancies and incorrect information on Mitchell I know I need a factory Ford manual and I will buy one however I am hoping some one here can clue me in about Mitchell on Demand sending me on a wild goose chase or not.
    Btw according to my owners manual fuse 15 under the dash is a 10 amp for the abs and yes it is good and has power.
    Number 15 under the hood is also for the abs it is a 50 amp with power both sides of fuse
    And all the other fuses in the car have power on both sides with the correct amperage rating fuse in each spot according to the owners manual
    Dec 2011
    Yonkers NY
    3,753
    I don't see a location 32.
    the cjb fuse loc is #15 (not 14) & it is 10A
    The BJB maxi fuse is 50A
    Feb 2018
    339
    Thanks
    This is what has me so pissed off because it means I cannot trust any of their manual since so much even connector locations and grounding points have been totally wrong.
    How can I test a pin point test with data that may or may not cause me to chase my tail.
    Feb 2018
    339
    I emailed Mitchell customer support and showed them how many errors I found on their site, they sent me what seems like every single page Alldata has to offer for the Abs syetm yet with no working links so it makes the data they sent basically worthless because it would take months to sift through this garbage to find the information I need.
    What A joke Mitchell is.
    37,149
    this is what I have on the fuse boxes
    Attached Files Attached Files
    20,630
    I have the 2000-2003 EVTM/service/etc manual on DVD. I can print to PDF any testing procedure you need. Not sure if it'll help since it requires special adapters and testers, but here's the ABS testing procedure...
    Feb 2018
    339
    Thanks I looked through the ( I am guessing Alldata ) information I was sent by Mitchell and the information you guys were nice enough to post all of it confirms only three fuses two small fuses in spots 1 and 15 both are good and one maxi fuse in spot 15 and it is good, all the fuses in my car have power on both sides of the fuse.
    For sure Mitchell ondemands website base is corrupted with garbage data apperentley a blind drunk money uploaded for them.
    Feb 2018
    339
    Thanks sly I looked through the information it seems the same as What I have but your download seems easier to look through than what mitchell sent me.
    I will say while reading this information I am now disapointed in my car, my wheel speed sensors are limitied to 255 MPH so much for breaking the 300 MPH record with my MGM LOL.
    I am not sure what Ford was thinking MY MGM would peel apart like a banana at 130 MPH if it got to that . LMAO
    20,630
    255 is a typical digital limit for computers. That's probably the limiting factor more so than the sensor.
    Feb 2018
    339
    It was just something I noticed and found funny.
    20,630
    Quote Originally Posted by EaOutlaw1969 View Post
    True. Little less arbitrary than the 160mph limit of my digital speedometer from Autometer. Really? You couldn't go more than 160? Then it dawned on me... if you convert that to KPH... 257... then it makes sense.
    Sep 2014
    Warren, MI
    5,243
    You kinda think that by today we'd be past that 255 limit with computers. This is reminding me of Y2K haha...
    37,149
    Consider the processing power we're talking about here. Also, realistically, why would you need for a production car to be capable of display beyond that point?
    Hell, I just wish I could get past the 85 hard limit on my own digital speedo. Its not possible for it to show more than 199 though.
    20,630
    I know there's a hack for most of the 80s ford digitals to switch from 85 to 140. They seemed to like to re-use those control ICs.
    Sep 2014
    Warren, MI
    5,243
    That's what Ghosty was saying about our Mark VII, that there's some resistor I could remove and it'll start reading beyond '85. I couldn't find it after referencing the Thunderbird(?) article he mentioned.
    20,630
    t-bird article: http://www.coolcats.net/modifying/199speedo.html
    Find the big chip... should be the same pin (37) if it's the same chip. Not sure if that's pulled to ground or voltage... I'm guessing ground. Looks like a ground plane that the jumpers get tied to.
    Sep 2014
    Warren, MI
    5,243
    Yep, that's the article. Trouble is I couldn't find pin W-2 and I don't think the chip is identical. That or I wasn't clever enough to see they were and just make a jumper like illustrated. Oh well, maybe the next VII we get? This one will be for sale within a week..
    20,630
    Yeah... I wish the t-bird article had a higher res shot of the board... and I also wish I could find the article on the Taurus digital dash mod. It had the option too.
