Aero TC Hearse... drum brakes?
    https://lynchburg.craigslist.org/cto...564524645.html
    So I remember that limos got some funky rear axle hardware like 31-splices. Did they also come with drum brakes well into the aero era?
    I did see one at a junkyard, didn't check the year though. Limo package supposedly got 31 spline and drums.
    LOUD EXHAUST IS FUN! AM I SHOUTING?
      all the ones I've seen were 11" drums.
        Same 11x2.25 drums as wagon/tow package boxes?
        How odd. I wonder what their reasoning was behind the drums, or the 31 splines.
          Looked like tow package drums. Only difference is they had an ABS tone ring in the mix. It was a stamped sheet metal "hat" that sat on the axle flange between the flange and drum for the sensor to read on.
          31 spline was probably just for strength, why the drums, not sure unless its parking brake / emergency brake related. The wee little baby drums inside the discs are much weaker in that department.
            also a larger axle (re: truck size)
              yeah it was a fatter shaft that used larger bearings than standard Panther stuff, I guess that would have been relevant to mention. The spline count is really not all that important since that isn't the weak point on the axle for these vehicles.
