As a quick aside from the exhaust work in my Lincoln thread:
When I removed my existing manifolds, there were no gaskets present, which I understand to be normal for the factory original manifolds.
If I reinstall the original manifolds, can I just bolt them right back on with no gaskets and making no changes to the mating surfaces?
I have gaskets on hand if needed, and expect I will need to use them for the 90 TC manifolds if I go that route, but I'm unsure if I need to use any when reusing the original ones.
