code 15
    code 15
    got this code after i installed a quarter horse any help
    thanks
    I want to say thats normal since the EEC was unplugged and now its running from a different memory source. Make sure the connections on the edge of the board are clean, but otherwise if the tuner is working I wouldn't worry about it. The code should clear if the program is good.
      ok thanks
        Normal, as the chip becomes the KAM. Code will not go away.
