95 town car mzt upgrade obd question
    Sup guys. I got my 04 cvpi air box and 80mm maf sensor etc.. I contacted mos speed shop and spoke with marty and he thinks i need the chip like 92.5 - 94 panthers would use, but not 100% sure. Mines is made 6/95 and it has the obd 2 plug. Does any one have any experience with a 95?
    1995 models are OBD-II, so they’ll be able to take a tune via a tuner instead of a chip.
    Running the later zip tube for the airbox will be your issue. The 1995 models used the ‘91-‘94 type intake. That puts the throttle body opening facing the the radiator support. The 1996+ have a different intake and their throttle body opening faces the driver side fender.
      Made 6/95 That could be a early 96 model, or a 95 model. If it's got the stupid intake... you can mate up with the 04 intake tube using a turn and straight intake pipe to reach over to the side... but it might be late enough to be the plastic intake. You would definitely need a tune when changing the MAF sensor. You could unbolt the MAF you have (the 4 bolts into the air filter housing) and bolt it to the new airbox if the bolt pattern is the same (can't remember, but I seem to remember my 93 MAF fitting on the later airbox I had). Then you won't need a tune, but may need a to wrap the MAF with a spacer to make up the difference to the new tube. Then swap on the new MAF when you get to the point of actually getting a tune done.
        Believe it is the same pattern sly but you lose the benefit of a larger MAF, however much or little it might be. If it's got the shitty intake, it could always be swapped to the later one, if one were inclined to change intakes. Seems like a lot of trouble to make 200hp but that's just me. 4.6 cars are cool but return on investment when it comes to speed parts is pretty depressing. That plus smog crap is why i sold my '98 and converted to boxes.
          The '04 airbox uses a slot MAF, right?
          No fitting yours in that, you'll also need some wiring changes to make it plug in.
          LOUD EXHAUST IS FUN! AM I SHOUTING?
            There's no benefit to the larger MAF without a tune. It may actually cause problems, though typically it just confuses the PCM and it may run lean before the O2s come on-line and help with fuel trim to fatten up the mix.
            Hence the reason I said to swap the whole housing off the filter box.
              Yeah, 2004+ CVPI and 2005+ Panthers have a one piece airbox top, nothing can be done without cutting.
                Forgot about the slot maf, which is ironic given that i used an '04 airbox on my box when i did the fancy top-end shit. I used a c&l maf with a SD mustang zip tube, cut the slot-maf part off the airbox and attached the c&l with a silicone coupler.
                Yes you'd of course need the tune with the 80mm maf and i believe adtr or blue oval chips sells an adapter if you want to use the slot maf. If you have the IAT sensor that goes in the airbox you'll have to drill a hole to re-install that unless you want to dick with wiring it into the later maf harness. I still have some 4.6 crap laying around i should get all together and sell.
                  Ah... that does put a damper on that idea.
                    1995 is a bastard year. I had to have a custom chip burned for mine to run the maf. It was not cheap.
                      Well, it isn't difficult to swap to the slot MAF. I do have one in my '89, if course, it was a change from no MAF so it may have been easier for me.
                        Thank you all for the info. I plan on doing this pretty soon. I have airbox, slot style cvpi maf with connector and wiring and part of the tube it goes in. And ill probly just "finesse" the stock tube on til i find a better solution. Couple more things. Does anybody have a certain tune i should get? And 2 does anybody have any info on how to wire new style maf sensor to my 95? Thanks
                          use this article to compare notes between the MAFs and reconnect wires as needed: http://easyautodiagnostics.com/ford/...sensor-tests-2
                          if you have a 4-wire, you will need to use the two wires from the air temp sensor mounted to the side of the MAF on the air filter box to tie the outer wires on the 6-wire MAF. Doesn't matter which one is which for that.
