Results 1 to 11 of 11
Thread: How to flush steering box?
  1. #1
    I post a lot...
    Nov 2005
    1,873
    Default How to flush steering box?
    I'll be replacing the PS pump & am wondering how to flush out the steering box.
    Any suggestions?
    Thanks Guys
    '10 Escape LTD, V6 AWD
    87 Ford LTD Crown Victoria Country Squire Station Wagon. 4.10's, Repacked Trac Loc, Boxed LCA's, Explorer Intake, 65mm T-body, 'Stang Cam, 'Stang Air tube, K&N, GT-40X Heads, 1" Spacer, 1 5/8 BBK's, 2.5" Pypes X-pipe w/high flow cats, Single Chamber Thunderbolts, B&M 'vertor, Po-lice Swaybars, Dead AOD.....
    '91 Mercury Grand Marquis Colony Park Station Wagon. K-Code, 4.10's, Repacked Trac Loc, MK VII LSC Engine, 'Stang Upper Intake, 'Stang Air Tube, K&N, 65 mm T-Body, 'Stang Headers, 'Stang Cat Pipe,'Stang Torque Convertor, 2 Chamber Thunderbolts...
  2. #2
    Mar 2010
    Lewisville, TX
    20,279
    The usual way is to feed the pump fresh fluid while dumping the old fluid into a bucket... having a gallon or 2 of type F (or merc III) on hand and someone else to crank the engine and turn the wheel lock to lock as fast as they can while you dump the fluid.
  3. #3
    Jan 2008
    New Jersey
    2,756
    Alternatively, what I have done is to feed the pump fresh fluid, and with the belt off turn the pulley by hand. I remove the return line and plug the nipple on the bottom of the PS pump, and let the fluid flow out of the return line into a container. Just another option, especially if the belt is already off
    -Phil
    +'82 Ford LTD-S Police Car. 351w, GT40 Heads, 2150 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Baumann Shift kit.
    +1975 Maverick- Fuel injected 302, Trickflow 170 heads, XE270 cam, explorer intakes, 24# injectors, custom tune. T5 transmission, 3.55 Yukon Trac-Lok rear.
    +1989 Mercury Colony Park "Large Marge" Lopo 302. 3.55L K-Code Tow package, Baumann Shift Kit, Big brake swap, rear discs, HO intake/TB, custom exhaust.
  4. #4
    36,429
    I also tend to do this by hand. You wouldn't believe how freaking fast those pumps move fluid. It makes a huge mess if it gets away from you. Turn it from end to end at least once, otherwise it won't get all the old fluid out.
  5. #5
    No mean-spiritedness here. IPreferDIY's Avatar
    Jul 2014
    Canada
    1,559
    I wouldn't be brave enough to try the motor running method. Here's what worked for me on my 2000 MGM:
    1. pull the belt off (if only to keep it from getting oily), suck the fluid out of the reservoir, pull the return line, tape a piece of plastic over the reservoir stub, and put some kind of sleeve between the return hose and a container;
    2. put jack stands under the front end, fill the reservoir, and turn the steering wheel fully to one side and back to the middle (which should be enough to empty the reservoir);
    3. refill, turn the steering wheel the other way and back, and repeat filling and turning to your heart's content.
    It seemed to me that you could get away with one quart for a basic fluid change, but you might as well buy at least two.
    I found that turning the pulley by hand only worked when the fluid was above a certain level. At a certain point, it wasn't going anywhere no matter how much I turned the pulley. I would guess the weight of the fluid comes into play.
    mods: air filter box "tuba" (in place of the "trumpet"), headlight relay harness, J-mod (around 186,350 km), 70mm throttle body, NKL4 PCM (from a 2000 CVPI, nothing great there apart from highway cruising), KYB Gas-A-Just shocks (after >202,000 km on originals)
  6. #6
    36,429
    yeah the pump will only move fluid if its above the intake level. Otherwise it just sucks air and does nothing.
  7. #7
    Mar 2010
    Lewisville, TX
    20,279
    yeah... I did use a 6 gallon bucket as my catch bucket and had my wife wheeling it with the front end off the ground. Managed to get the wheels back and forth about 3 full cycles before emptying out the "flush" quarts. I used 2 for that one. Having a full gallon on hand would have been much nicer. But yeah... gotta pour fast. It flushes the system QUICK.
  8. #8
    Jul 2014
    Canada
    1,559
    What I was talking about was the fluid going down some but getting to a certain point where there was clearly still some fluid in the reservoir to keep it from sucking air, but it wouldn't go any lower. After putting more fluid in the reservoir, it went down to the same level but no more.
  9. #9
    Sep 2014
    Warren, MI
    4,947
    Like other people said, I second turning pump by hand. Pumps pump pretty well yo. Easier on the bearings & starter this way, plus it's easier to stay "caught up" with what's going on rather than accidentally empty the pump reservoir. Mercon V works pretty well at quieting noise down, Type F just as good, if not slightly better. Stay away from parts store brand.
  10. #10
    36,429
    Quote Originally Posted by IPreferDIY View Post
    You guys with roundy cars use different pumps too. Our reservoirs are integral to the pump, they probably pump down to a lower level than the external tank sort.
  11. #11
    Mar 2010
    Lewisville, TX
    20,279
    I've flushed the box and my aero running. When I did the aero, I had the return line poked into the drain hole on the top of my oil catch pan. That was much less messy than the open bucket. It was much easier to keep fluid pouring into the wide mouth of the box pump though. I was barely able to keep up with the aero.
