looking for the electrical plug that connects to the thermal control switch under the hood on one of the heater hose lines that is used with automatic temp control also need a few inches of wires connected to it to splice it to my existing wires that were cut and spliced together to bypass the switch when it was removed from the system. Found the switch from my old blue 2 door that i had been looking for for a couple years
Atc plug
Any chance this is the one?1990 Country Squire - weekend cruiser, next project
No not it. this plug has only 2 wires. what it plugs into shuts the blower motor off until temp of the coolant reaches about 120* in the heater hose from the water pump to the heater core. it also has 2 vacuum lines connected have one of the vacuum connectors.Scars are tatoos of the fearless
Thermal blower lockout. NA. Just bypass it. Tie the wires together. If you really want to have the function, use something like an NTE-DTC120 and mount that to a hose coupler (preferably metal for better heat transfer) that hopefully has a flat spot to add some thermal grease between the flat spot and the NTE part and drive a relay to switch the wires on. It's a 30A fused circuit, so you'll need a relay big enough to handle that. The vacuum lines can be plugged. The function of that is to keep recirc door closed until at switch temp and keep the blower off. Most folks just bypass the stuff when it finally breaks since there's no replacement except used.
Originally posted by sly View PostThermal blower lockout. NA. Just bypass it. Tie the wires together. If you really want to have the function, use something like an NTE-DTC120 and mount that to a hose coupler (preferably metal for better heat transfer) that hopefully has a flat spot to add some thermal grease between the flat spot and the NTE part and drive a relay to switch the wires on. It's a 30A fused circuit, so you'll need a relay big enough to handle that. The vacuum lines can be plugged. The function of that is to keep recirc door closed until at switch temp and keep the blower off. Most folks just bypass the stuff when it finally breaks since there's no replacement except used.Scars are tatoos of the fearless
oh... you're putting it back. Yeah... Good luck. That plug gets brittle and doesn't like to be messed with, so finding one intact may be difficult. Doesn't seem they have that wire harness aftermarket any more. It's almost the same as the power window motor connector except the clip is on the long side instead of the short side.
