Did they use a small rear sway bar on these because of cost issues or would a larger rear bar make it oversteer? If it would help performance I'm grabbing a nice fat rear bar.
Small rear sway bar on 2010 cvpi?
How small are you talking about? The CVPI rear bar was not the largest, that belonged to the HPP from what I've seen.
Getting a pair of larger bars(ADTR) is the normal upgrade.
LOUD EXHAUST IS FUN! AM I SHOUTING?1989 Country Squire - Twilight Blue, 347 stroker
the balance front to back is important. If you get a larger bar in the back, grab the front bar off the same car86 Lincoln Town Car (Galactica).
You should see my 03 Expedition. The front bar is about 2 inches or so... the rear bar is about half an inch.
size of rear bar is dictated by spring rate. LX cars with softer spring rate got a 17mm rear bar. Police cars with higher spring rate got a 18mm rear bar. HPP and cars with RAS got a 21mm rear bar due to the higher spring rate the air springs can generate.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
