So the NOS coffee can I just received D9AZ-19A566-A lists for some trucks and Crown Vics and MGM's (1980)........but with manual a/c control. Since my '86 Tudor 5.0 has ATC will this make a difference?
ATC VS Manual control
ATC uses more vacuum, so you may still have issues with the shorter can, but it should work for the most part.
You need the can for Cruise control at least in some years and to keep the blend doors in the right position when going uphill and or flat out. Put the can in, check the vacuum switch and the hose. I patched mine with epoxy till it stopped rusting out as all the rust prone spots were replaced by the resin.
I had been stumped, Ivan found my hose to the can had collapsed so there were no leaks but the can was never vacuumed.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
This is a study in elimination .......I replaced the hose from the tree to the can last year.....no change.....I then put in a NOS valve, no change.....so now I will first have my bud pull 20" of vacuum with his hand held vac tool,, then watch the vac scale for one minute......if it reduces more than 5" then the can is deemed to be N/G....according the Ford emission manual.
epoxy if it is the can. What problem are you chasing?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Smoke machine. Helped me discover my tubular upper intake was warped.~David~
Make sure all the vacuum lines are actually on the actuators good. My major leaks were with the blend door actuator (the big ass can behind the glove box... just needed to have the line pressed on fully) and 2 of the vent actuators behind the ash tray (same issue). The only car I've ever had to replace a line on was the Lincoln Mark VI I sold to sxcpotatoes. After replacing that line, that AC was ICE cold.
The temperature control system is never not in automatic mode. The only thing you can take in and out of automatic is the fan.
Check the function of that check valve too. NOS has that whole "old" thing in it. It may be NOS NFG.86 Lincoln Town Car (Galactica).
Continued thanks to all.....btw, how do I check function of the "new" valve, I mean before I bust my balls to get it in....how do I pull vac on it with a "Mity-Mite hand held tool?Originally posted by gadget73 View PostThe temperature control system is never not in automatic mode. The only thing you can take in and out of automatic is the fan.
Sly never thought of that....will have to check those lines!!Originally posted by sly View PostMake sure all the vacuum lines are actually on the actuators good. My major leaks were with the blend door actuator (the big ass can behind the glove box... just needed to have the line pressed on fully) and 2 of the vent actuators behind the ash tray (same issue). The only car I've ever had to replace a line on was the Lincoln Mark VI I sold to sxcpotatoes. After replacing that line, that AC was ICE cold.
Cap off one of the small lines on the check valve. Apply vacuum to the other. If it holds, the check valve is good.
http://www.lincolnsonline.com/tech/00130.html86 Lincoln Town Car (Galactica).
