Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Flexplate to AOD Torque Converter
  1. #1
    Nov 2006
    Dirty Jersey Yo!
    7,672
    Question Flexplate to AOD Torque Converter
    When you guys swap out your torque converters, do you have trouble getting them back onto the flexplate; stock or aftermarket? I have a Ford Racing flexplate that isn't matching up to the torque converter studs. I tried matching the TC up to the stock flexplate and it doesn't match either. So I concluded that he TC is off. I was told by the TC manufacturer to ream out the holes in the flexplate. Is this the proper thing to do? My Dad says to return the TC and get another as the studs should match without machining anything.
  2. #2
    36,539
    I've never had a torque converter not fit the flexplate correctly. Agree with your dad, you shouldn't need to mess with the flexplate. If you oversize the holes and its not perfectly centered the crank and the trans may not actually be perfectly in line with each other. That will make for vibration and it'll beat the hell out of the bearings.
  3. #3
    I post a lot...
    Dec 2011
    Yonkers NY
    3,605
    What Gadget and Dad said.
    Also..
    I am guessing it is an aftermarket converter?
    You can check the flexplate by lineing it up with the original converter.
  4. #4
    Mar 2006
    Bedford, VA
    4,685
    What’s the part number of your Flexplate? A quick look showed me only a Ford Racing flexplate for coyotes.
    Measure from one stud to the other on the opposite side on the torque converter , then check the flexplate. Should be 11.5in IIRC.
    1988 Crown Vic Wagon - daily
  5. #5
    Nov 2006
    Dirty Jersey Yo!
    7,672
    Gadget73: That was my feeling too. My Dad used to hang around his friend's machine shop when he was not working; so when he tells me that something is wrong; I tend to believe him. But, I had to ask anyways.
    jaywish: Aftermarket converter; Monster Transmissions to be specific. Unfortunately, the lopo is long gone along with the original AOD. Couldn't keep it around the yard as we were getting complaints. There some parts that I failed to get off of the lopo that I had to go to the JY to get.
    Tiggie: I will get the FRPP flexplate number this weekend; perhaps during the work week if I can get out of here at a reasonable time
  6. #6
    36,539
    Invest in a privacy fence, or a house not located where people complain so much.
  7. #7
    Nov 2006
    Dirty Jersey Yo!
    7,672
    Most definitely need to get out of north Jersey. Seems like everybody is like that up here these days. Too many people from the metropolitan area that are not accustomed to living with DIY people; but that culture is dying anyways. :-/
  8. #8
    Nov 2006
    Dirty Jersey Yo!
    7,672
    So, I am attempting to install my AOD onto the back of my engine and have run across a snag. My new torque converter measured out to 11.5" and slid onto the flexplate smoothly, but the holes on the flexplate are shifted a little so that a couple of the torque converter studs are up against the sidewall. There is no play with the torque converter despite getting the "3 clunks" and having 1/4" clearance between the tip of the studs and bell housing flange. I have had people tell me to bore the stud holes in the torque converter out 1/16" and again, my Dad and his machinist buddies are telling me not to do that. Not sure what to do again. I feel that I shouldn't have it tight like that, but I am a little squeamish with boring/reaming holes on things that need to be centered.
  9. #9
    36,539
    I don't understand what you mean. What sidewall?
    Is the converter bottomed out against the flexplate before the engine and trans are all the way mated? It shouldn't be. Normally when the engine and trans are mated, the converter can slide back a small amount from the flexplate. Not enough to get the studs through, but enough to not be hard against the flexplate either. Do you have the aluminum shim plate on the back of the motor? It needs to be there. Is this a stock Ford flexplate or something else? And this isn't an engine from a manual trans vehicle is it? The pilot bearing may interfere with the torque converter if its got one in the end of the crank still.
  10. #10
    Nov 2006
    Dirty Jersey Yo!
    7,672
    Trans and engine are mounted together; no binding; no hassle. I just don't have any play with the torque converter. I has pictures....
  11. #11
    36,539
    dunno, either the converter stud bolt circle is a CH large, or the flexplate is a CH small. If one is a real Ford part and the other is not, blame the aftermarket item. If both are aftermarket, who knows. You'd need to very accurately measure it to see which is off. Eyeball says the wrongness is probably not over 1/8" center to center.
  12. #12
    Nov 2006
    Dirty Jersey Yo!
    7,672
    TCI converter to Ford Racing flexplate. I'll ask some questions; may need to get the matching TCI flexplate. We'll see......
  13. #13
    36,539
    Do you have the factory flexplate or converter? That will tell the tale.
  14. #14
    Nov 2006
    Dirty Jersey Yo!
    7,672
    I have the factory flexplate that came with the engine, but the CV AOD and stock converter are long gone. Not sure what transmissions came on a ‘96 F-250.
  15. #15
    36,539
    see if the stock flexplate fits to the new converter. if it also doesn't fit right, the converter is screwy.
    F250 should be an E4OD, but I think the bolt circle on the flexplate is the same.
  16. #16
    Nov 2006
    Dirty Jersey Yo!
    7,672
    It fits the factory flexplate that came with the donor engine; not smoothly though; I have to jiggle it in order for it to slide onto the studs. I may get the matching TCI flexplate in hopes that it works with the torque converter. I pulled the "Ford Racing" flexplate off to take a better look and I see no numbers on it; ring gear looks like it was replaced at some point. I also noticed when taking the transmission back off the engine that the torque converter snout must have been rubbing the back of the crank. I will remeasure everything and record what numbers I have; I am getting the "3 clunks" when installing the torque converter though; it is pushed back as far as it can go into the trans. Here are the latest pictures
  17. #17
    Nov 2006
    Dirty Jersey Yo!
    7,672
    Observation: it appears that all of the studs (I rotated the crank to see all of the studs) favor the 3o'clock side of the stud hole on the flexplate.
  18. #18
    I post a lot...
    Dec 2011
    Yonkers NY
    3,605
    As a guess I would say the converter is a bit off. I would put $5 that the stock unit would fit the FRP plate. That said you might be right about a TCI plate & a TCI converter.
  19. #19
    Nov 2006
    Dirty Jersey Yo!
    7,672
    I retrieved the kickdown cable and bracket, and the gear selector bracket on the side of the transmission, but I failed to take the TC. I didn't think I would use it; live and learn :-/
  20. #20
    36,539
    yeah, bolt circle is a CH big on the converter.
