Testing rear defroster?
    The hand test doesn't produce any heat. I want to see if there is power to it.
    Tim
    2000 Ford Crown Victoria
    84 Lincoln Town car signature, R.I.P
    85 Ford LTD Crown Victoria 2 door performance project
    89 Lincoln town car: RIP
    89 Crown Victoria LX 2002 USACi sound quality world champion RIP
    1990 Mercury Grand Marquis LS
    1994 Mercury Grand Marquis (sold)
    2004 Mercury Marauder. owned for a week then got screwed by the dealer
    Multimeter. Black lead on one contact, red lead on the other. Check for resistance. If you get OL, the grid is broken. Not sure what the value of the grid is supposed to be though. I would expect less than 1K ohm. To check if power is getting to it, in volts mode, black lead on a good body contact (I usually use the striker bolt for this one) and then red lead on the grid contact. I think the passenger side on boxes is the +, but I could be wrong.
      I'd meter across both leads just in case the connection from grid to ground is bad.
      usually they don't feel noticeably hot, or at least I've never noticed it. The frost goes away though so I know its working except for that one grid thats open right in the middle of the glass.
