ClayBelt’s 2010 Mercury Grand Marquis, “The Douche”
    Got my tune in the mail from Marty today. Shift points may need a little adjustment, but otherwise it feels like the car lost 200lb or something
    2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
    1966 Ford Thunderbird (390FE) “Fordy McFordface” - engine rebuild No. 3. 11/2016-
    RIP 2005 Buick LaCrosse CXS “Jumba” - gone too soon, 229K. 6/2017-2/2018
    RIP 2001 Chevrolet Tracker LT “Featherbrick” - gone too late, 156K POS. 6/2016-9/2016.
    Sold 2005 Toyota 4Runner SR5 - 198K. 6/2016-4/2018
      Good to hear. I may end up throwing my zip tube/80mm MAF/ Airbox on as well, since it's taking up room in my garage, and see how well it runs (or how far I can push the stock computer).
      Keep it up.
      08 Lincoln Navigator L - 233k
      03 Mercury Marauder- 63k
        It should run well enough on the stock computer man. I didn’t run into any issues until I added a bigger throttle body into the mix
          I also PI swapped a non-PI car. Still using the stock computer.
            Ordered new upper control arms yesterday day for her. Gonna need new front shocks too soon enough.
              Well, we’re on day 2 in the parking lot, and the car is getting towed to a dealer tomorrow morning. Control arm job went wrong.
                what happened?
                  Ball joint stripped, so I hired a mobile mechanic service to come out and finish the job while I was at work. They managed to break one strut in disassembly and punch a control arm bolt far enough in to cut halfway through the spring on the other side, while cutting through the bad ball joint with a sawzall. Tried to fix it myself, but I couldn’t figure out how to do the spring with the bolt lodged in it so I could remove that arm. Ended up calling the mobile guy everyone in my store uses. He started work today, but it won’t be done until Wednesday or so since he has some other customers he had lined up already while working on mine. Went that route instead of the dealer cause it’s a lot cheaper still
                    Switched over to red tails instead of grey ones. I have a second set that I am chopping up to make sequentials work, deemed th greys too expensive to replace if I botch the job
                      I love the Merc next to a Smart car. Lol.
                      Past Panthers
                        I make it a point to park next to those whenever I can. It looks silly.
                          Looks silly?!? The fact that it only gets 37mpg or whatever on HIGH TEST GASOLINE is CRIMINAL
                            It’s even made worse when there’s larger compacts than it, that not only get more MPG on Regular, but also are more practical and usually cost less.
                              Popped one of the Dorman heated seats in the car today. Discovered I put the heater element too far forward on the bottom of the seat, but it does it’s job well, which is the point.
                                Thats a heater element that goes under the seat material ?
