Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 45
Thread: Grand Marq from the Czech Republic
  1. #21
    Aug 2018
    Czech Rep
    26
    If I decide to use BBK shorty headers - these: https://www.summitracing.com/int/par...ions/year/1987, is there any issue with space between the engine and front axle/frame or they will fit?
  2. #22
    Apr 2006
    MI
    3,805
    The ones that come closest are the equal length shorties, they come close to the steering shaft.
  3. #23
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,099
    I am running stock Mustang headers on the '91 and UNequal length BBK'S on the '87. They were installed years ago. I do not recall any issues with either install.
    The 91 is a mostly stock HO, the stock 1 1/2" headers are well matched for low RPM.
    The 87 is highly modified, I think you would lose low end torque with 1 5/8" pipes on a basically stock HO. So be realistic in what you are assembling.
    Keep in mind that a system that is well matched will perform better than a bunch of "trick" parts that are just thrown together.
    '10 Escape LTD. V6 AWD, K&N, Bullitt wheels.
    ‘87 Ford LTD Crown Victoria Country Squire Station Wagon. 4.10's, Repacked Trac Loc, Boxed LCA's, Explorer Intake, 65mm T-body, 'Stang Cam, 'Stang Air tube, K&N, GT-40X Heads, 1" Spacer, 1 5/8 BBK's, 2.5" Pypes X-pipe w/high flow cats, Single Chamber Thunderbolts, B&M 'vertor, Po-lice Swaybars.
    '91 Mercury Grand Marquis Colony Park Station Wagon. K-Code, 4.10's, Repacked Trac Loc, MK VII LSC Engine, 'Stang Upper Intake, 'Stang Air Tube, K&N, 65 mm T-Body, 'Stang Headers, 'Stang Cat Pipe,'Stang Torque Convertor, 2 Chamber Thunderbolts.
  4. #24
    Aug 2018
    Czech Rep
    26
    OK, I don´t want to lose low rpm torque, as this is the thing I love the most on the old american V8s.
    The engine is non HO, so installing these headers without any other mods make no sense. Im just thinking how to dig some more HP from the engine, because once it will be disassembled, why not to put some better stuff there But maybe without HO conversion or other heavier mods it will be not possible
    Another question. I need to order a new oil pan. On rockauto I found two possiblities, w oil level sensor hole and w/o oil level sensor hole. I think, when my car is a base model, I need the one without the hole, right?
    Check these photos of the car, my colleague did them in our company´s parking lot. I think he did a great work
    https://www.flickr.com/photos/151988...7694663416990/
  5. #25
    5,095
    I’m not a MGM expert, but all of them I have ever seen have the low oil light. If you have the light in your instrument cluster, and you have the sensor in the left side of the oil pan, get the new oil pan with provision for the sensor. Or you can delete it and use the other pan... the light won’t work but who really uses the check oil light anyway.
    1988 Crown Vic Wagon - daily
  6. #26
    Aug 2018
    Czech Rep
    26
    I have this base cluster, only with oil pressure light. Or is it for oil level too?
  7. #27
    21,045
    That's pressure only.
  8. #28
    Aug 2018
    Czech Rep
    26
    So we finaly startedClick image for larger version.
ID:	51232Click image for larger version.
ID:	51233Click image for larger version.
  9. #29
    Aug 2018
    Czech Rep
    26
    And I bought rustfree trunk lid. Here in Czech Republic, in Prague. For less than 50 bucks, a miracle
  10. #30
    18,585
    Really. I would have never thought you would have found that!
  11. #31
    21,045
    +1 score!
  12. #32
    Nov 2005
    2,099
    Have fun with your project.
    Nice garage!
  13. #33
    Hell I can’t find body parts in Minnesota let alone rust free ones. How the hell did it end up there?
  14. #34
    Aug 2018
    Czech Rep
    26
    Hi after long time Last Saturday I purchased this rear end from burned LTD Crown Vic. I want to put it on my GM. The guy I got it from told me this is LSD. I didn´t open it yet. So what you think I have? If this rear end has different diff ratio, will it cause issues with transmission?
ID:	51539Click image for larger version.
ID:	51540Click image for larger version.
ID:	51541Click image for larger version.
  15. #35
    5,095
    The tag appears to say 2.73, which would indicate a 2.73 open differential. Could have had an LSD added but doubtful. At least you got a rear sway bar included.
  16. #36
    21,045
    Unless that's been replaced... it's an open diff. The tag would say 2L73 for a LSD.
  17. #37
    BANNED! sxcpotatoes's Avatar
    Jan 2008
    Northeast Ohio
    2,750
    Those rear swaybars are Police Interceptor/Cop car only and nigh unobtanium in the states. Take $100 off whatever you paid for that rear end just for including that awesome part.
  18. #38
    Aug 2018
    Czech Rep
    26
    Quote Originally Posted by sxcpotatoes View Post
    I paid equivalent of 70USD in local currency As far as I know, the car from which is this rear end taken was imported from Canada more than 20 years ago and before the front part burned (electrical issue) it was in very good condition.
  19. #39
    GMN Regular Giraffe's Avatar
    Jan 2016
    Wichita Falls, TX
    823
    Easiest way to tell if it's limited slip or not is to turn one axle. If the other side turns in the opposite direction, it's an open differential.
    —John
  20. #40
    21,045
    Quote Originally Posted by Giraffe View Post
    or a completely wasted LSD.
