Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Rear control arms for sway bar
    all the CFI are belong to me
    Feb 2014
    Windsor, ON
    1,405
    Default Rear control arms for sway bar
    I've been led to believe that boxes equipped with a rear sway bar, and perhaps a certain handful of cars not equipped with it (but not all of production in general) have rear lower control/trailing arms constructed of thicker steel:
    The issue on the rear arms is not so much the holes. Any arm can easily be drilled for the second set of holes and the lips neatly and easily rolled. More significantly is the thickness of the metal used to construct the arms. My 89 wagon came stock with the heavy constructed arms that were not preped for a sway.
    Reportedly many/most other cars came with arms that look identical but are made of a slightly thinner steel. So take a set of calipers to your existing arms and compare that to the ones in the yard. I no longer have the dimensions.
    I now own two rear sway bars; one skinny one mounted to arms mounted to an axle which is sleeping at Derek's house currently, and one fat bar with no arms (but do have the hardware).
    I would like to put the fat bar on my Lincoln (along with the corresponding front bar), but I am concerned about this 'different control arm construction' issue. Do we know what happens if you put a rear bar, particularly the fat one, on the skinny arms? Are they just a little more flexxy or do they actually fail from fatigue?
    Worth noting I have not verified it has the skinny arms, just assuming it does. I can't find measurements to confirm what is what.
    83 GM 2dr | 84 TC POTM 1/2017 (Pre-Op) | 85 CS | 85 Ranger | 91 GM POTM 12/2017 | Junkyards thread/imgur
    4,802
    Been running the fat one on the 88 for about a decade of daily use without issues on whatever crusty rusty trailing arms. I doubt we’d see any kind of failure.
    Also not sure of the gauge metal on the HD arms. Need someone with a clean PI car to measure. I can measure the cleaner/no rust arms on the 90 wagon tomorrow if no one has a measurement on standard ones.
    1988 Crown Vic Wagon - daily
    Nov 2014
    Evans, GA
    1,191
    I have the HD police control arms, but never installed them on the ‘87. The factory arms on it had the two holes, so I just rolled the edge slightly and bolted it in place. No issues with the install and the body roll was significantly reduced.
    -1987 Grand Marquis Colony Park LS (323K Miles) - The Hideaway & April 2017 POTM Winner
    Apr 2015
    Southern Commiefornia
    2,016
    Yep, put a PI bar in the rear and an addco front on the '90 with no issues. If you're terribly concerned, box them with some of those plates like i bought and never installed.
    Feb 2014
    Windsor, ON
    1,405
    As long as folks have bolted the bars to the stock non-HD arms and did not experience a critical failure as a result in the couple years following, that's good enough for me.
    I want to clean up or paint or something these bars but I also want to feel exactly how much of a difference they'll make, and it's not particularly hard to put them on or take them off, so I'll go for it I guess.
    When you say 'rolled the edge' I imagine we're talking about where the edge of the arm is bent out at 90 degrees from the vertical wall of the arm, and just further curling that up?
    Nov 2014
    Evans, GA
    1,191
    Terrible picture since the bar wasn't the focal point here:
    It's the rolled edge at the bottom. I took some vice grips and just bent it down ever so slightly until the bar set into the grove nicely and lined up properly with the holes. The HD arms are flat in those areas.
    I definitely noticed a difference the the sway bar. The rear end used to have a little bit of a wandering sensation on rough roads and on tight turns. Ride quality was not impacted with the addition, but it did help keep the car more level during turns by reducing overall body roll. If you prefer the "can it lean enough to one side it might fall off the springs?" turning feel, YMMV.
    Jan 2008
    New Jersey
    2,773
    Gauge thickness is covered in this sticky:
    http://www.grandmarq.net/vb/showthre...ase-Read-First!
    "The rear control arms I have on my 89 Grand Marquis are .08 thick (left pic), and the ones I bought today are .10 thick (right pic). So the police rear control arms are made out of 12 gauge steel and the non-police rear control arms are made out of 14 gauge steel if the chart I googled is right.
    Thickness (Inches)
    Gauge Num.---Nominal---Tolerance Range
    12 gauge------.1046------.1106 to .0986
    14 gauge------.0747------.0797 to .0697
    +'82 Ford LTD-S Police Car. 351w, GT40 Heads, 2150 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Baumann Shift kit.
    +1989 Mercury Colony Park "Large Marge" Lopo 302. 3.55L K-Code Tow package, Baumann Shift Kit, Big brake swap, rear discs, HO intake/TB, custom exhaust.
    Feb 2014
    Windsor, ON
    1,405
    Thank you. Somehow that doesn't surprise me, but it irritates me that Google could not seem to come to the same conclusion through its indexing against my search queries (as a general rule, when I say I've searched for something, I Googled my query with site:grandmarq.net at the end).
    I do like body roll but this car has a lot of it. Too much, by reasonable standards.
    36,864
    My car had arms with the holes and the lip already, but I never measured the thickness. Its had a police rear bar on it for more than 10 years without any problem.
    Apr 2015
    2,016
    Frankly i've been wondering if a cobra IRS would fit in the back of our cars. Only downside then is that the front suspension would be archaic in comparison. Sure would make these turds handle better though.
    BANNED! sxcpotatoes's Avatar
    Jan 2008
    Northeast Ohio
    2,648
    Yeah, there's a world of difference with the rear swaybar. Go over bumps, or railroad tracks, feel how the car WIGGLES? There's a shimmy in the rear if you don't have the control arms linked with that bar. It's a solid feeling now going over any road imperfections and it makes turning somewhat tighter (maybe not objectively) and more fun.
    18,201
    Another one here running the thick police rear bar on stock lower arms. My father did it when he got the car ages ago. No issues here.
    Member Luke's Avatar
    Dec 2018
    Hamilton Ont. Canada
    20
    Hey im new here but want to put a set of bars on the front and rear of my 89 marquis from a police car. Does it matter what year car they come from and can i re use my from end links? And does the rear install right to the lower control arms or are there end links also?
    1989 MGM & 2016 Tacoma
    18,201
    No end links in rear. I don't see a reason you cannot reuse stock front end links. You can get sway bars from any year box panther police car. The difficult part is finding that nowadays.
    20,468
    79-91 should work for you up front and in the rear. Rear is control arm mount. You can reuse your end links and just replace the bushings. The energy suspension bushing kit is $20 at most local parts stores that carry them. It's not specific to these cars, but they work fine.
    36,864
    I've not had great luck with re-using front endlinks. They break a lot of the time. If yours aren't rusted and they come apart though, you're good.
    Dec 2018
    20
    Awesome thanks. Theres police cars all over the place around here but their all newer. I was hoping i could use one, wishful thinking
    Member Elias's Avatar
    Mar 2016
    Dallas Texas
    297
    I message chris from adtr A few days ago about this. Would be cool if he could make a upgrade for the rear control arms. Since on his vic he has the metco rear arms. He said he would think about it.
    Dec 2011
    Yonkers NY
    3,660
    BTW my X 89 wagon came with the heavy gauge steel control arms but no sway. The bars were not rolled nor did they have the second set of holes to mount the bar. So I don't know if only wagons got the heavy bars or any later box. The only way I could tell the difference between the (early?) thin bars and these was with a gauge.
    It was an easy conversion. Just roll the lower lip a bit, mount up the bar to the single set of holes, drill the second set of holes using the bar ass a template.
    Dec 2018
    20
    I wonder if theres any other models i can look for at scrap yards that could have the bars for our boxes
