2004 CVLX: the new winter beater
    One steering shaft DONE.
    Believe it or not, this isn’t even the worst one I’ve ever seen...but it’s way worse than the one that failed on my old 2004 MGM.
    '91 LTD Country Squire LX | '82 Cougar GS wagon |'03 Marauder | ' 18 Flex Limited EB
    formerly: '02 MGM, '04 MGM, '04 MGM v2.0, '04 MM, '07 P71 w/5-speed, '03 SAP P71, '04 CVLX (now in pantera77's stable), '10 P7B
      Originally posted by a_d_a_m View Post
      Yeah, it’s a Chinese grille with a too-small badge.
      Is the chinese badge pad the correct size for a proper Ford badge? Mine (SAP grille) is peeling chrome and I was eyeing the rockauto offerings.
      Alex.
        The badge is larger on a honeycomb grille than on the chrome or other slatted grilles, so what Adam has going on there is a honeycomb grille with the smaller badge likely off of the original chrome grille.
        -Steve
          Thnaks.
          Alex.
            If I remember correctly, the badge used on the honeycomb grille is the same size as the one on the rear of a Windstar or older F150. There are several options if you need one since it seems that Ford only used a few sizes of Ford emblem for a long time.
            -Steve
              Welp, after a year of service, the car finally needed an entire exhaust system minus the cats.
              Started with manifolds that looked like this when removed:
              Then turned into a failed flange at the Y on the single exhaust. My buddy had a junk P71 dual setup laying around (with the fire suppression insulators on the tailpipes!) so I had him hack off the old one and weld new junk onto this car. BEWARE: OHIO RUST INCOMING.
              He had some damn near empty spray paint around so I did a bumper tuck and tried to make the rust look pretty. There wasn't enough paint to do a good job.
              If I can get one more winter out of it, I will be happy.
