Which a.c. clutch cycling switch 90 Colony park
    Hello again, what part numbers both original and aftermarket for the a.c. clutch cycling switch for a 134 converted 1990 Colony Park?
    THANK you,
    Mike
    pretty sure its the same switch used on everything for a decade or more. The only difference between an R12 one and an R134a one is the pressure setting might be tweaked. They are adjustable though, so you can tune it yourself if needed. Of the two I've had to replace, both were old Motorcraft. One was NOS, but probably pushing 30 years old and it failed after 2 months in service. The aftermarket ones seem to work fine though.
      yeah... the stock replacement for my 93 works fine with the 134a in the system. Same with the Mad Marquis (88 MGM) I used to have.
        Thank you Sly and Gadget. I always appreciate your help and knowledge.
