Results 1 to 11 of 11
Thread: Loss of power to trans, wiring harness problem
    BANNED! sxcpotatoes's Avatar
    Jan 2008
    Northeast Ohio
    2,648
    Default Loss of power to trans, wiring harness problem
    The '03 Ultimate I sold my nephew is having a problem with the transmission, long story short, he wrecked it, then he ran it out of oil after a botched change (filter gasket leak etc). It was a little noisy because of timing chain guides or whatever, and finally it started getting 'laundromat dryer with a box of bullets' noisy, and the motor was swapped with an '04 motor. A week after the successful motor swap, the transmission stopped shifting. I don't know how much he's been driving it in the MONTH since that happened, but FINALLY it got into the transmission shop, and they have NO POWER to the trans. Shop owner messed around with it for about an hour, and figured out it has power to a point (blows the transmission fuse every time now) but doesn't want to tear through the entire harness.
    I'm thinking it would it be a good idea to just run a new power wire from the fuse panel to where the trans wants juice, think that's safe? It would at least let us try to drive it and see if he's destroyed the transmission completely. This car has been J-modded, but the 1-2 accumulator spring was left in it. Another thing, during the motor swap, the mechanic changed the front trans pump seal, since it was accessible with the motor out. Probably doesn't have anything to do with the problem, since it seems to be electrical.
    Jan 2008
    Northeast Ohio
    2,648
    Here's a video of driving it to get the engine swapped. http://youtube.com/watch?v=2D-1Rs5-gXQ
    Mar 2007
    North Las Vegas Nevada
    2,175
    Check for a trouble code you might need to go through the herness and replace the.hernes My mom's car had a rodent eat through her wire herness and I got a solid "check engine" light took her car to dealer and they fixed her car including doing a front end inspection got that fixed bad bushings caused weird steering now good.
    36,862
    Unplug the trans harness at the main engine harness and see if it stops blowing the fuse. If it does, the problem is in the trans harness or the trans itself. If that clears the fuse problem, plug the harness in but unplug it from the trans. If the problem stops, its internal. If not, its in the harness. If the trans harness is dicked, find a used one or tear into the existing one and fix it. Its not all that big, and opening it for inspection is just a utility knife and a bunch of tape to unwind. I would not just supply power without knowing why the fuse is blowing. Pretty sure its also key-on power through the PCM relay. If you just run power to the trans without fixing the problem its still going to blow the fuse.
    Jan 2008
    Northeast Ohio
    2,648
    Sorry I never updated this, the Oxygen Sensor harness was grounding out through the transmission wiring or something. I dunno, it got fixed up for like $350, and in the process I found a new shop that doesn't mind troubleshooting electrical stuff and isn't bad on price.
    20,467
    Bonus!
    Sep 2014
    Warren, MI
    5,166
    LoL if you were in New York I'd say you visited South Main Auto, that guy is a wizard with electrical diagnosis.
    Apr 2015
    Southern Commiefornia
    2,016
    Very nice. The shop that does all my work is namely an auto-electric shop, but they do everything so i'm extremely lucky to know them. That, and my buddy works there so it's a win-win.
    Jan 2008
    Northeast Ohio
    2,648
    The other shop that normally did my electrical troubleshooting was backed up since May, so he recommended this other place that he trusted.
    36,862
    Electrical troubleshooting is easy. Basically it always comes down to disconnecting things until it stops fucking up, then move in the direction that reduces the number of things disconnected until you find the single part that isn't working.
    20,467
    It's time consuming though. That's the real issue most of the time.
