Results 1 to 5 of 5
Thread: Refurbed Seat Switch
  1. #1
    I post a lot...
    Nov 2005
    1,956
    Default Refurbed Seat Switch
    Driver Side Seat Switch ceased to function. The seat was locked in a position that could be utilized (Albeit somewhat uncomfortably) by my Wife and eldest Son, I however could not get into the car…
    2 screws to remove the Switch.
    Removed the contacts with a small amount of screwdriver persuasion. Used a marker to make dots where they made contact to ease reassembly.
    Removed cardboard insulator.
    Removed the center section by depressing the clips with a pick and jiggling it out.
    Used a small pick to pop the 4 clips from the switch body.
    Lots of leetle pieces.
    Used some contact cleaner and a clean rag to clean all the contacts
    The “rocker” contacts were filthy & pitted, used some 220 grit on them (would have preferred something finer but that was all that was on hand). Finished them off with some contact cleaner.
    Same process on the 4 pins in the main body.
    Could not find my Conductive Grease so I reassembled it dry.
    Carefully reassembled the unit, used hemos to reinstall the rockers.
    It now works great.
    (Of course I found the Conductive Grease right after I reinstalled it)….
    '10 Escape LTD, V6 AWD. K&N, VentVisors
    87 Ford LTD Crown Victoria Country Squire Station Wagon. 4.10's, Repacked Trac Loc, Boxed LCA's, Explorer Intake, 65mm T-body, 'Stang Cam, 'Stang Air tube, K&N, GT-40X Heads, 1" Spacer, 1 5/8 BBK's, 2.5" Pypes X-pipe w/high flow cats, Single Chamber Thunderbolts, B&M 'vertor, Po-lice Swaybars, Dead AOD.....
    '91 Mercury Grand Marquis Colony Park Station Wagon. K-Code, 4.10's, Repacked Trac Loc, MK VII LSC Engine, 'Stang Upper Intake, 'Stang Air Tube, K&N, 65 mm T-Body, 'Stang Headers, 'Stang Cat Pipe,'Stang Torque Convertor, 2 Chamber Thunderbolts...
  2. #2
    37,149
    ah, so thats how to get them completely apart. I've pulled the rubber cover and the paddles off before and just poked in there with a pick to scrape them clean enough to work. Next time I have one go flaky I'll pull it completely apart so maybe it will stay fixed. Every few years the one on the Towncar goes goofy. Or maybe it dies in 2 weeks and I only notice it every few years when I have to move the seat for some reason.
  3. #3
    Mar 2010
    Lewisville, TX
    20,630
    Aero ones are much easier to get apart... but about the same amount of little bits that like to disappear. Reassembly is definitely a balancing act.
  4. #4
    Stow It! GM_Guy's Avatar
    Sep 2008
    Ontario, Canada
    3,153
    Whale ones have small dumbell rollers, and contacts set in plastic. You can guess what happens to the plastic when the contacts get hot.
    Alex.
  5. #5
    Sep 2008
    Whitestone, NY
    18,300
    Cool Jim...Hope I dont have to rip into one of these. lol
