Results 1 to 10 of 10
Thread: Rear stabilizer bar 21 mm
    Apr 2018
    Ustroń, Poland, Europe
    85
    Default Rear stabilizer bar 21 mm
    In my MGM I have 15 mm rear bar and I would like to upgrade it to 21 mm, but I can't find it on ebay, etc. Is it possible to find it? It can be used ofc. I have possibility to buy 17 mm bar, but I'm afraid that difference between 15 and 17 mm bars will be imperceptible - am I right..? Or maybe the best solution will be buy Addco 650 25 mm ?
    09 Grand Marquis LS - Light Ice Blue, Medium Light Sone interior, Heated seats, 17" rims,
    Nov 2014
    Evans, GA
    1,232
    Normally I'd say check the junkyard, but I doubt finding one with what you want in Poland is happening. The Addco would be your best bet unless one of us shipped one to you, but who knows how much shipping would cost.
    IIRC, some HPP models came with the 21mm bars, but someone correct me if I'm wrong.
    -1987 Grand Marquis Colony Park LS (325K Miles) - April 2017 POTM Winner
    Doctorate in Redneck Engineering
    Jul 2018
    Leon County
    162
    The HPP always came with the 21mm bar I believe. I would say Addco bar as well, but you could just wait for one to pop up from an HPP or Marauder instead. The Addco would require you to replace both to avoid being a little too happy to swing on one end or another on the car.
    2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
    1966 Ford Thunderbird (390FE) “Fordy McFordface” - engine rebuild No. 3. 11/2016-
    RIP 2005 Buick LaCrosse CXS “Jumba” - gone too soon, 229K. 6/2017-2/2018
    RIP 2001 Chevrolet Tracker LT “Featherbrick” - gone too late, 156K POS. 6/2016-9/2016.
    Sold 2005 Toyota 4Runner SR5 - 198K. 6/2016-4/2018
    Jul 2014
    Canada
    1,607
    Here's a link for what got what:
    http://www.idmsvcs.com/2vmod/suspens...rtnumbers.html
    It looks like all HPP had 21mm while police had 17mm. The following notes at the bottom of that page seem particularly pertinent:
    "Police rear swaybars are 17mm. Police coil springs are very stiff.
    Civilian Handling Package rear swaybars are 21mm but they are coupled with the relatively low rate civilian rear air springs"
    The 21mm bars seem to be easy to get at junk yards in North America for cheap. I got one from a local U-pull yard for ~$15CDN with taxes. The shipping to Poland would probably be the biggest cost. If you're sure a 21mm bar would be worth your while, you can post something in the "Looking to Buy" section. One of the folks who frequent the junk yards could probably hook you up in short order.
    Apr 2018
    85
    Thank You Guys ! Do we know which front bar had Marauder ?
    Jul 2014
    Canada
    1,607
    It looks like the Marauder had a 28mm front bar:
    Apr 2018
    85
    Which parts I also need to change with 21 mm bar ? Bushing for sure - what about link and bracket ?
    Jul 2014
    Canada
    1,607
    Yup. Bar, bushings, brackets, and links are the complete setup for rear and front. If you get a used bar, you might as well make sure it comes with the brackets. Both the rear bar and rear brackets can get pretty rusty, so you should give consideration to removing rust and painting them up nice, even if the ones you get don't look bad. New bushings and links can be had for decent prices, so I wouldn't bother with used ones.
    Apr 2018
    85
    But brackets and links are different for 15 and 21 mm bar ? I understand that bushing are different, but the rest ?
    Jul 2014
    Canada
    1,607
    I don't know the variations with absolute certainty, especially for 03+, so hopefully someone else can verify. AFAIK, the rear links are all the same regardless of bar size. The bushings are obviously size-dependent, though I would think the brackets are all the same. If you get the brackets with the bar, you should be fine.
