Might be worth a look to someone close by or someone with a trailer.
https://phoenix.craigslist.org/evl/c...701555721.html
From the ad:
"White with tan cloth interior and black floor mats. Tag on side of dash reads: State of California Dept. of Parks & Recreation. Cold-starting, strong 351 Windsor V-8. Variable-venturi carb. Axle code 8: open 2.73 rear axle. Rust-free body. Tinted windows. Goodyear Integrity radials on 16" rims. New valve cover gaskets and plug wire set. New water pump; new radiator. New battery.
Odometer stuck at 99,933. Plenty of tread still on brake pedal. Overdrive out in transmission; previously 19 mpg highway (calculated using Mapquest and gas receipts). Fuel gauge does not work; low-fuel warning light is always on. Air bag light is always on. No A/C, most probably a shot compressor. Heat works well. Driver's window works well; right & left-rear come down but raise poorly; right-front doesn't work. Rusted H-pipe held to tailpipes by splints made of scrap exhaust pipe and clamps. Contact crack on dash. Vinyl NASCAR roof numbers can be removed.
$1500 firm or ad will be continually rerun."
From the ad:
