Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: Valve Covers in a Box w/ 351W
    Nov 2006
    Dirty Jersey Yo!
    7,968
    Question Valve Covers in a Box w/ 351W
    Are the stock valve covers the only ones that will fit under the wiper motor cover? It looks like once I get under the wiper motor, the plastic cover that it mounts to becomes an issue. I have to mess with it some. Has anybody run a taller-than-stock VC with a 1.7 rocker arm ratio? If so, what brand (part#)?
    Nov 2006
    Dirty Jersey Yo!
    7,968
    Just thought about something (yes, it happens every once in a while); what is underneath the black plastic cover that the wiper motor mounts to? I'm wondering if I can take a heat gun, heat the bottom of that cover, and press it upwards a little to create a dome for clearance.
    39,261
    The crank arm on the wiper motor itself is right there, along with the linkage rods. Push into that too much and the wiper transmission will not be able to move.
    I don't remember what Phayzer was running on his, but I'm reasonably sure it still had a wiper motor in it. They were not factory valve covers but thats all I remember.
    Jan 2007
    Westmont, New Jersey
    10,373
    I'm pretty sure the 351 valve covers on the police cars were taller than that of the SEFI covers.
    39,261
    I think you may be right on that. They look a lot like the CFI stamped steel covers, which I think are taller than SEFI stamped. Those boring old SEFI covers have a lot of available space inside, so you may be OK for clearance. I'm running 1985 stock aluminum Mustang covers with 1.7 Scorpion rockers and it works. Possible there is only the thickness of a sheet of paper in there, but nothing hits and it hasn't broken the valve cover yet.
    Apr 2015
    Southern Commiefornia
    2,345
    On my edelbrock performer heads with the stud-mount conversion kit it makes the rocker setup really tall. When i did the top-end on the other car i had to get tall motorsport valve covers to clear all the shit. If you're running pedestal rockers on stock or pedestal heads, you shouldn't need a very tall cover.
    Nov 2006
    Dirty Jersey Yo!
    7,968
    Thanks guys. I will mess with it over the weekend and see what can be done. I got FMS valve covers at a swap meet and it just might be them being super tall.
    Jan 2007
    10,373
    Some of the aftermarket heads have a taller valve cover mating surface than factory production ford heads. So a shorter valve cover may be able to be used. However in some cases, the additional height there may cause clearance issues. Then again, I don't know exactly how much taller those ones are. I believe the Trickflow heads have raised valve cover surface.
    Apr 2015
    2,345
    Yeah the problem i think was that they were pedestal-mount heads with the conversion, so the rocker mounting surface ends up a lot higher, creating clearance problems. Same shit is going on my 347 since i already have the valve covers and stuff anyway. Unless of course i score a set of afr's in the meantime for a great deal.
    Cheese Nazi phayzer5's Avatar
    Irving, TX
    3,793
    The ones I'm running were a set of cheap chrome clad ones from a Ford Racing appearance kit i got way back in the day. I've only had them installed on my 408, and that had stud mounted 1.72 scorpion roller rockers. Never took the covers off with the engine in the car, only on a stand outside. They do in fact make it a bitch to reinstall engine/trans at the same time, but my 7qt oil pan probably deserves more of the blame for that
    edit: here's a pic
    '80 Town Coupé
    Nov 2006
    Dirty Jersey Yo!
    7,968
    I have a 7qt Canton pan myself. Even with my engine mounted, it's still a tight fit. Fighting with the valve cover studs that came with the valve covers. The shop either torqued them down; and/or used Lock-Tite. I will double jam nut the studs and get them off; then see if I can get the valve cover back on and see what I have to work with.
    39,261
    skip the valve cover studs, there isn't enough room. I've got a set that I tried using but I couldn't get the valve covers in position. 1/4-20 stainless hardware works though, can go with socket key cap screws if you want something a little fancier looking.
    19,152
    I use two studs strictly for aligning the covers and gaskets back in place.
    39,261
    They work for that but having studs permanently under that wiper box would make removing the valve covers a huge PITA. The alignment studs I use for the intake are awful handy too but it would make removing the lower intake a huge PITA if they lived there full time.
    19,152
    Agreed. Studs for install reasons only. Otherwise removing things become an absolute chore/impossible.
    Nov 2006
    Dirty Jersey Yo!
    7,968
    When I pull the studs out, I will replace them with Allen head bolts. There is a hardware store a few miles from me that has all of that stuff. I didn't know enough at the time the engine was rebuilt that the stud kit would be this much trouble. Otherwise, I would have gone a different route. But then again, many things with this project became unforeseen problems :-/ Live and learn
    Nov 2006
    Dirty Jersey Yo!
    7,968
    Baffles in the valve covers; what purpose do they serve? Can I live without them?
    19,152
    If there is a baffle below the oil fill tube you may have engine oil sucked up into the throttle body if it gets removed.
    39,261
    Keeps oil from getting sucked up through the PCV or pushed back out the vent, depending what it is doing. Also helps keep it from splashing the bottom of the fill cap and causing it to leak.
    Nov 2006
    Dirty Jersey Yo!
    7,968
    Okay. I am thinking of getting the Ford Racing EFI valve covers that I got a decade ago and removing the baffle(s) to fit the 1.7rr. I have a oil/air separator to help with keeping oil out of the intake. I guess I will just have to keep an eye on it. This is assuming that my current valve covers won't fit under the wiper trans cover.
