Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: code 56 98
    Default code 56 98
    how to fix
    37,311
    56 is usually a bad MAF or a short in the wiring. You're getting full 5v reference voltage back to the ECM.
    98 is probably because of the MAF. Its a hard fault in the ECM, basically meaning some sensor input is completely bonkers and its ignoring things.
    try unplugging the MAF and see if the codes change. If they do not, examine the wiring between ECM and MAF for shorts. If they do, the MAF is probably dinked.
    My screen name is GREEN, Bitches ! 88grandmarq's Avatar
    North Georgia
    2,194
    what Gadget said...
    56 is MAF circuit above maximum voltage.
    98 is FMEM (failure mode effects managment) which means the ECM is ignoring the signal from the MAF and running on a previous, good static value.
    faulty/incorrect wiring or failed MAF.
    Found couple wires frayed took them apart and re-solder them now everything is fixed now my problem is it doesnít wanna start when it reaches temperature
    195 up starts up cold and when itís below 160.
    20,738
    Last time I had issues with that, it was the engine coolant temp sensor pigtail. Check all the temp sensors to make sure they're working and check the wire harness for them to make sure they have continuity back to the ECM. Unless it's not cranking at all... that would be the thermal lockout in the starter gone to crap.
    changed coolant temp sensor and act also.ill check wires next
    all wires are good
    20,738
    Have you verified that the new sensors are good?
    ECT: http://www.grandmarq.net/oldfuelinjection/page28.html
    ACT: http://www.grandmarq.net/oldfuelinjection/page29.html
    test them cold... warm it up and then test them again. If they don't change, you got a bad one. The ACT may not change much, but it should get a little warmer.
    sensors are good checked codes got code 11 on koeo koer
    20,738
    Weird. Guess something that was unplugged and plugged back in had a bad connection and that solved it.
    doesn’t wanna start when it reaches temperature problem still have
    37,311
    you measured the sensors at temperature to confirm they read properly when warm ? They can give faulty readings but still within the range of ECM acceptable so it won't code.
    Does it start if you add some throttle?
    20,738
    There were times the Mad Marquis would take a full 5 seconds to crank over.
    37,311
    your starter sounds slow and uneven. Might be the problem.
    brand new starter and new red top optima
    GMN Regular Giraffe's Avatar
    Jan 2016
    Wichita Falls, TX
    812
    One possible thing to look into: I've had two Ford vehicles over the years that eventually suffered from a corroded starter power wire (wire from the solenoid to the starter). It would crank just fine when cold, but would either crank very slowly or just click solenoid when hot. The engine bay temperature would be enough to raist the temperature of the corroded wire to the point that not enough current would get to the starter to start the engine. The symptoms seem more like a dead battery, but yours is new. I did originally did the same thing as you (replaced battery with Optima red top and new starter), but still had the problem until I replaced the starter cable.
    óJohn
    1990 Mercury Grand Marquis LS (POTM March 2017)
    20,738
    What were the measurements of the temp sensors at temp?
    Also, have we checked the grounds on the engine?
    Are the ECM and fuel pump relays working right? Are they loose in the connectors?
    Relocated battery to rear all new 0gauge wire.did voltage drop test cold and hot nothing wrong there.when hot I have spark and fuel pressure it just doesnít run it just cranks.put new distributor with ford pip new relocated tfi cap rotor plugs wires new coil.all new act ect MASS-AIR sensors checked all wires fuse links also swapped cpu with good one and problem still there Iím lost on this
    4,913
    To me it sounds like the timing is advanced way too far. Rotate your distributor counterclockwise and see what happens.
    1988 Crown Vic Wagon - daily
