code 56 98
    brand new starter and new red top optima
      One possible thing to look into: I've had two Ford vehicles over the years that eventually suffered from a corroded starter power wire (wire from the solenoid to the starter). It would crank just fine when cold, but would either crank very slowly or just click solenoid when hot. The engine bay temperature would be enough to raist the temperature of the corroded wire to the point that not enough current would get to the starter to start the engine. The symptoms seem more like a dead battery, but yours is new. I did originally did the same thing as you (replaced battery with Optima red top and new starter), but still had the problem until I replaced the starter cable.
      —John
      1985 Ford F-150 XLT Lariat
        What were the measurements of the temp sensors at temp?
        Also, have we checked the grounds on the engine?
        Are the ECM and fuel pump relays working right? Are they loose in the connectors?
          Relocated battery to rear all new 0gauge wire.did voltage drop test cold and hot nothing wrong there.when hot I have spark and fuel pressure it just doesn’t run it just cranks.put new distributor with ford pip new relocated tfi cap rotor plugs wires new coil.all new act ect MASS-AIR sensors checked all wires fuse links also swapped cpu with good one and problem still there I’m lost on this
            To me it sounds like the timing is advanced way too far. Rotate your distributor counterclockwise and see what happens.
              Also are the injectors getting open signal when hot?
                Is the TPS getting power when hot? (This will let you know if the other sensors are getting power. This will also let you know if the ECM is having a 5V regulator issue.
                  Got Power and pulse to injectors and got power 5v to tps
                    I really am out of ideas now.
                      other than cranking weird I have nothing either. Could be timing, could be something starter or wiring related.
                        pulled#1 spark plug found oil on threads.then checked them all #5 had oil too could this be my problem for hot restarts
                          Dunno myself, but for the sake of clarification, has the engine been running just fine after getting to normal operating temperature after a cold start?
                            starts fine cold reaches opt temps runs fine just when shut off hard to restart
                              Will it eventually restart hot or do you HAVE to wait for it to cool down? Will it start with SPOUT jumper pulled?
                                HAVE to wait for it to cool down.never tried with SPOUT jumper pulled
