Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: 1997 Mercury Grand Marquis aka the rolling junkyard.
  1. #21
    Member Pvt.Hudson's Avatar
    Aug 2005
    Assachusetts
    57
    +1 PITA, but not near as bad as suspension stuff. Just f'n messy.
    Took me all day. Need to get one of those spring clamp pliers. Trying to use channel locks or vise grips is a pain in the royal ass. Had issues with the coolant overflow hose clamp and the OFA one. Also the wiring loom that runs down the side of the OFA is just dumb. I couldn't get the wire back on to the bracket because when you do that it blocks the second bolt that goes into teh block.
    While the radiator and coolant overflow hoses went easy enough the OFA one I couldn't get off, seeing as I was replacing the upper & lower hoses I just cut the hose with my tin snips to start then hack sawed it off then took the hose off with my massive channel locks.
    Partway through when I got the camera.
    Had to JB weld the pressure switch cover. It cracked with the quickness, no surprise considering its been on the car since 11/1996.
    Have seen worse, not much corrosion or pitting.
    Reason for the leak, the rubber rings of OFA gasket failed to remain pliable. The oil ports on the gasket were completely flat flush with the plastic surround.
    Gates hoses fit good.
    No leaks now.
    1997 Grand Marquis LS HPP
    - Richard
  2. #22
    Nov 2005
    Upstate, NY
    5,123
    Very nice.
    I pop the poewr steering pump when I have to do those. I found it makes it suck a little less.
    08 Lincoln Navigator L - 173k
    03 Mercury Marauder- 60k
    97 Ford Crown Victoria HPP "Tank of Justice III" (TOJ3) - 193k -->578.9 miles on ONE tank of gas<--
  3. #23
    Aug 2005
    Assachusetts
    57
    Misplaced the gasket then found it. The oil port gaskets are completely flat:
    - Richard
  4. #24
    Nice build car looks good.
    10/2018
    2006 Mercury Grand Marquis
    Ole Blue Hair
  5. #25
    Aug 2005
    Assachusetts
    57
    Been installed for a week now. The lower mileage of the replacement column feels good no squeaks when turning and the shifter feels like new.
    Still gotta sort out the media buttons as the resistance values the HU sees are just to close. Like I set MEM to be mute but I can spam vol+/- or BAND and it will mute. Sometimes it takes repeated pressing to get it to function too. The Horn, EATC controls and speed control work no issue. Also the backlighting only really works at full brightness, anything else the buttons will dim or go to full brightness regardless of setting depending on steering wheel position. Don't have a air bag light in my cluster but the warning tone of the air bag control module only beeps when air bag is disconnected.
    Got a replacement button pod and gonna try that.
    - Richard
  6. #26
    Aug 2005
    Assachusetts
    57
    Got a replacement media/eatc button pod and a few other things.
    Also scored a 1998 TC steering wheel in proper denim blue in awesome shape for $20 so I'm gonna use that. Also noticed that the leather is a lot thicker then a aero TC wheel. Also gonna try the 98+ single stage air bag and see what happens. If it fries the air bag control mod internal fuse I have access to quite a few aeros so no big deal there. The resistance value of the 98+ air bag is only about 1 ohm higher then a aero first gen airbag. I don't like the plastic Lincoln logo over the embossed one but its in the proper color.
    The pcb of the replacement button pod looks in better shape then the one I have so I'm hoping that it will solve the illumination and the media buttons having to close of resistance. The button pod I'm using the pins on the pcb look kind of gross:
    - Richard
  7. #27
    Aug 2005
    Assachusetts
    57
    New one is on left is much better looking.
    - Richard
  8. #28
    Aug 2005
    Assachusetts
    57
    So a whale bag in a aero is no go:
    Button swap not sure but the buttons do respond faster for the stereo but they are still very close in resistance values and still finicky. Have to do more troubleshooting on that end.
    Now I gotta find a place that will mix SEM Colorcoat to denim blue so I can paint the airbag in the proper color. Removing the buttons pods on my 97 steering wheel damaged the paint so the original prairie tan is showing.
    - Richard
  9. #29
    Nov 2014
    Evans, GA
    1,471
    Shame. I'd love to have a proper Mercury emblem on my steering wheel, but the Continental airbag will just keep on at this rate. I truly believe all Whales rolled out as Second Generation air bag vehicles, unless somehow super early build 1998s made in late 1997 rolled out as unicorns sporting a first generation until but I find that doubtful.
  10. #30
    Sep 2014
    Warren, MI
    5,591
    You know, that blue trim doesn't look so bad contrasted against the gray dash. Don't know if I said this already but I applaud the blue interior conversion. I absolutely hate gray. It's like the most bland yet most popular interior "color" and I wince to call it a color. Give me blue, black, tan or red/burgundy please.
  11. #31
    Member BigMerc96's Avatar
    Jun 2011
    I can see Detroit from here
    517
    Seeing as my job 1 1998 (2/15/98) sports "second generation airbags" stickers on its windows, I think its safe to say all '98s are 2nd gen. The module is on top of the trans tunnel on a '98+, its physically too big to fit in/on the pillar where it is in my '97.
    I still need to get the '98-'00 Townie clockspring so I can retrofit redundant controls to my '98. I have 2 redundant control steering wheels to choose from in the correct color. The original one from my Townie and the wood rimmed '02 Continental wheel that is in the Townie now. The '02 wheel is actually Medium Parchment, but its really close to the Prairie Tan in my Townie. Actually not 100% sure which color the '98 has, that was the changeover year and the 2 colors are so close I can't tell.
    -Steve
  12. #32
    Aug 2005
    Assachusetts
    57
    Changed the shocks as they started getting a little softer and the supplied bushings were toast on the fronts.
    KYB fasteners flash rust the second they are installed. Had to snap the studs on both front shocks. And when it came to the rears I used a 15mm when it should've been a 14mm and stripped the pass side.
    Took two Milwaukee blades to get through the rubber bushing.
    Old one out:
    New one in:
    - Richard
  13. #33
    5,207
    The bean counter who didn’t allow the extra 0.5 cent it could have cost for upper shock mounting access through the trunk should be lynched.
    Glad you conquered them though. I need to do the same on my 90.
    1988 Crown Vic Wagon - daily
  14. #34
    Aug 2005
    Assachusetts
    57
    Second time I've done them. First time I ever changed rears myself on a panther was on this car. My previous panthers I'd take it somewhere else and pay someone else to do them.
    When I got the car it had rear Monroe OESpectrums and came out without a fuss and the front were original or replaced a long while ago Motorcrafts. Had to snap the front studs on those Motorcrap shocks. This time I learned my lesson and sprayed some cosmoline on the fasteners so if and when I need to remove them again it won't result in destruction of the shock to remove them.
    Hoping I can warranty these KYB's on RA without any fuss. Sucks you gotta pay return shipping. Wish they had a regional drop off place.
    - Richard
  15. #35
    Aug 2005
    Assachusetts
    57
    Found a 1997 CV P71 PCM for cheap and swapped it. KBS3 is the tear tag ID.
    Been almost a week. Gonna keep it in. It shifts a lot better then the original PCM. Though it has made the 1-2 shift even more herky jerky probably do to it being the original weak accumulator design.
    - Richard
  16. #36
    Aug 2005
    Assachusetts
    57
    New tires to replace the $254 china no seasons I was previously running:
    Sumitomo HTR ZII in 235/60-16.
    They actually ride harsher then the 18s (Michelin Xice3 215/55-18) and were a bit squirrely when first installed but now that they have some miles on them they grip pretty good. Also adjusted the rear height as it was to low in the rear now it sits proper.
    Finally got around to replacing my worn out sway bar bushing by buying replacement bushings that came with a new bar:
    Old one out
    New one in
    A whale P71 29.5mm bar. Its nice not hearing anything clunks on the front end now.
    - Richard
  17. #37
    Aug 2005
    Assachusetts
    57
    Finally got around to resoldering my cluster that was reading 0mph and getting 99mpg at WOT and getting my damn media buttons to work.
    So far so good. Hack noob soldering but the cluster is now working.
    F U N !
    Got my media buttons working. So it turns out if you want to retain steering wheel controls using aero TC redundant control steering wheel you need a adapter. When I initially installed the TC wheel in January I tried the PAC SWI-RC but I couldn't get it to work. So I just connected it directly to the stereo but it still was glitchy. Turns out the steering wheel controls for the stereo/eatc aren't resistive but voltage based so thats why a adapter is needed. Its a pita to program but I got the SWI-RC to program and now the buttons work as they are supposed to, no more press same button twice and get three different results.
    Also managed to somehow break the shifter cable adjustment bracket, probably back in January. No wonder I couldn't get the indicator in Park. Fixed it with some loctite epoxy, hold it holds cause there isn't any aftermarket part listed for panthers and not sure if the Dorman part for trucks would work (in theory it should considering most of the rwd Ford steering columns are the same but who knows).
    - Richard
  18. #38
    Mar 2013
    New Haven, Indiana
    1,212
    Junkyard builds are by far the best kind of builds. I love how interchangeable panthers are.
  19. #39
    Aug 2005
    Assachusetts
    57
    Permatex plastic epoxy no go on holding the shifter indicator cable bracket together.
    JB Weld with a staple for reinforcement seems to be holding up a lot better:
    Should've used JB Weld to start with.
    - Richard
  20. #40
    Aug 2005
    Assachusetts
    57
    Drier/Accumulator decided to rot out thanks to the foam insulation koozy. Leaked the PAG46 oil all over the right front chassis.
    Removing it.
    Installed new drier/accumulator, orifice tube, orings and painted the retaining ring.
    Was looking to replace the temp spare tire but the prices on those are almost $100, found a HPP for $40 with a tire that isn't 22+ years old so now a member of the full size spare club.
    Swapped from gray 2001 dual visors to proper denim blue ones from a 2000.
    Found a 1999 Denim blue package tray with speaker grills. Was gonna use a 2000 one but it has no speaker grills just holes under the carpet. Swapped it out now the interior is done. Looks good with the gray speaker grills.
    - Richard
