Weird horn
    Weird horn
    My 1997 Marquis horn is weak with ignition off and strong with ignition on.why? Thanks
    How is your battery doing? Sounds like it may be dickered. Of all the electrical crap in a car, horns usually pull the most current, right behind the starter. So with a weak battery, I could see the horn being weak but when running, a properly functioning alternator will keep the battery at like 14.7V or what not.
      I will test the battery thanks
        +1 battery probably has a weak cell. Have someone crank the car. If it drops below 11V before it starts, you have at least 1 weak or dead cell.
          +1. I have a voltmeter installed in my car, and I can watch it drop considerably when the horn is on. I'll check it out today and try and get an approximate voltage drop. Also, I have two pairs of factory horns installed, so it draws a bit more power, lol.
          08 Lincoln Navigator L - 233k
          03 Mercury Marauder- 63k
            Mo powah!
            I've thought about installing the four note Cadillac horns in my cars. That would require quite some juice.
              Mo powah!
              Do it! I can help get more power to those horns, and I'm sure Kevin would help too.
                Well with that kind of support how can I say no? I'll have to start looking at Cadillacs at yards now. Was a bit of an obscure option and GM horns don't work all that well after so many years but they are fixable.
                  Another thing I want to do
                  2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
                  1966 Ford Thunderbird (390FE) “Fordy McFordface” - engine rebuild No. 3. 11/2016-
                  RIP 2005 Buick LaCrosse CXS “Jumba” - gone too soon, 229K. 6/2017-2/2018
                  RIP 2001 Chevrolet Tracker LT “Featherbrick” - gone too late, 156K POS. 6/2016-9/2016.
                  Sold 2005 Toyota 4Runner SR5 - 198K. 6/2016-4/2018
                    Thank you it was the battery a bad cell
