I mentioned elsewhere that I was purchasing a cheap quad headlamp relay harness to try out on my Continental. Its the same quad lamp arrangement most boxes use, or anything else with four sealed beam lamps. The one I bought is this one
https://www.ebay.com/itm/Ceramic-H4-...72.m2749.l2649
I'm sure this same kit can be bought from other sellers, it seems to be all over ebay. Shipping takes a bit, but its free. Order was 9/28, it showed up in NJ on 10/27, so essentially a full month to arrive.
Pulling it out of the envelope it looks like it does on the auction. Wires, relays, sockets. Initial impressions are that its not terribly made but its not exactly a high end exotic part either. Some detail pics of the assorted connectors and such below.
Fuse is one of those cheap ones like you find at Harbor Freight. I'd suggest replacing it with a proper brand one. A bit of silicone grease in the terminals wouldn't hurt either.
rear view of the relay sockets. One thing I'm not sure I like is that power for the low beams routes through the normally closed contact on the high beam relay, meaning that if the high beam relay burns that contact out, you've got no low beams. I may change this at some point but likely I'll give it some run time first to see if it holds up.
The relays. These appear to be decently sealed and constructed. Its a standard Bosch-style relay socket and pinout though, so replacements are easy to get.
Views of the sockets. Its un-glazed ceramic, probably wouldn't be too hard to damage if you poke at it but it doesn't seem too fragile to use. Again, I suggest silicone grease in these terminals to help weatherproof it.
Some very confidence-inspiring words of wisdom
