WTB: engine brackets/mounts/hardware for a 4.6 aero or early whale (02 and older)
    from a 4.6 aero (could also be a 4.6 whale with the old crossmember 2002 or earlier) looking for the engine mount brackets that bolt to the frame and the actual mounts with rubber that bolt to the engine and all hardware...
    Let me know what you have! Looking to avoid a long day at the J-yard!
    Thanks!
    1984 Mercury Colony Park Wagon - gone to the darkside. 5.3 LS Turbo Swap with 4L80E. 6.62@106 in the 1/8 mile (low 10's in the 1/4), full weight, AC, no compromises! Rocky Mountain Race Week 2020 and Race Week 2.0 2020
    Have you checked at rock auto? they're less than $15 each. Mounts are one of those parts that if they're available, just get the new since they're usually stupid cheap.
    https://www.rockauto.com/en/catalog/...tor+mount,5552
      Yes on the mounts for sure, but i need the brackets and the hardware too as I'm doing a swap that needs all that stuff
        gotcha.
          I remember when we put the 302 in the 92 Grand Marquis, all we did was replace the motor mounts. Thats the part that sits between the frame and the engine, there are no brackets or frame mounts. I'm reasonably sure the 4.6 works the same way.
            I just pulled the motor out of my 84, definitely a bracket bolted to my engine and the mount bolted to the frame. For the 4.6 I know there is a mount bolted to the motor and a bracket bolted to the frame...i found someone selling one of the frame brackets on ebay, but it's NOS and $30...
              Here is the frame mounted bracket for a 4.6 Aero...this is what I need for both sides plus hardware:
              https://www.ebay.com/itm/OEM-Ford-Le...frcectupt=true
              and here is the motor mount for that bracket:
              https://www.ebay.com/itm/91-97-fits-....c100005.m1851
